First post, by Shagittarius
- Oldbie
So I'm having a problem with my 160GB drive when attempting to install windows 98SE.
I've been skipping the scandisk portion because it always finds problems with the drive about the space reported.
When windows 98 starts to copy files i get a message that:
A serious error has occured while writing to drive c retry (r) in a little box in the upper left corner.
I was previously using this drive with another system and everything was working perfectly. I moved it for a better CPU and had driver conflicts so then I attempted to restore a clean ghost i had which killed the drive by marking everything as bad clusters.
So I went back to basics, I've tried fdisk, i've tried 3rd party utils. I zeroed out the drive using killdisk but no matter what I keep getting this message.
I can install XP no problem onto the drive, I did this to test it. I know I've done this before but I can't think of how I would have done it differently before. Does anyone have any suggestions?
The system is a Duron 1.6 I think, it's a shuttle system like the last shuttle the drive was in just a different CPU and motherboard.
I read about fixes for large drives but I didnt have to do this before and It's failing on the install so I'm not sure that's where the issue is.
Also I'm wondering if I used a version of Win98SE from the developers kit we had at work and maybe it's my version of 98SE? Unfortunately if that was the case those cds are long gone now anyways.
Also VSAFE is not running.
