Reply 200 of 311, by Skyscraper
Yea I'm running the CPUs at stock at the moment. The onboard USB is not very found of overclocking and can flake out even at 140 MHz FSB. It's a known issue and easily solved with a PCI USB card but those are in storage...
Other than that the DVD266 is supposed to do somewhere around 145 - 150 MHz FSB running AGP 4X, a bit more running AGP 2X and much more when using a PCI video card. The AGP implementation seems to be this motherboards weakness.
As this is supposed to be a year 2001 build and 1400 MHz seems right on the money for what I would been able to get with PIII-S 1.26 CPUs Im pretty happy with running the 1.4 CPUs at stock anyhow.
