Reply 60 of 144, by Neon_WA
for reference this is what I have in P2 xeon
  • 400 100 512 Q626ES
    400 100 512 SL2RH
    400 100 512 SL34H
    400 100 1024 SL2NB
    400 100 1024 SL34J
    400 100 1024 SL35P
    450 100 512 Q799ES
    450 100 512 Q809ES
    450 100 512 SL2XJ
    450 100 512 SL33T
    450 100 512 SL36W
    450 100 1024 Q666
    450 100 1024 Q810ES
    450 100 1024 SL2XK
    450 100 1024 SL33U
    450 100 2048 Q667ES
    450 100 2048 SL2XL
    450 100 2048 SL33V
    DS2P THERM SAMP REV. 1 Q501
and in P3 Xeon
  • 400 133 256 QE61ES
    500 100 512 Q879ES
    500 100 512 QB56ES
    500 100 512 SL2XU
    500 100 512 SL3C9
    500 100 512 SL3D9
    500 100 1024 Q883ES
    500 100 1024 QB98ES
    500 100 1024 SL2XV
    500 100 1024 SL3DA
    500 100 2048 SL2XW
    500 100 2048 SL3CB
    500 100 2048 SL3DB
    550 100 512 SL3AJ
    550 100 512 SL3FK
    550 100 512 SL3LM
    550 100 1024 SL3CE
    550 100 1024 SL3LN
    550 100 1024 SL3TW
    550 100 2048 QB76ES
    550 100 2048 SL3CF
    600 133 256 SL3BJ
    600 133 256 SL3SS
    667 133 256 QE66ES
    667 133 256 SL3ST
    667 133 256 SL3WP
    700 100 1024 QX47ES
    700 100 1024 SL49P
    700 100 1024 SL49Q
    700 100 1024 SL4RZ
    700 100 1024 SL4XU
    700 100 1024 SL4XV
    700 100 2048 QZ89
    700 100 2048 SL3WZ
    700 100 2048 SL3X2
    700 100 2048 SL49R
    700 100 2048 SL49S
    700 100 2048 SL4R3
    700 100 2048 SL4XX
    733 133 256 SL3SU
    733 133 256 SL3WR
    733 133 256 SL3WS
    800 133 256 SL3WT
    800 133 256 SL3WU
    800 133 256 SL4H8
    800 100 2048 QU34ES
    866 133 256 SL3WV
    866 133 256 SL3WW
    866 133 256 SL4HA
    900 100 2048 SL4XY
    900 100 2048 SL4XZ
    933 133 256 QY19ES
    933 133 256 SL3WX
    933 133 256 SL3WY
    933 133 256 SL4HC
    1000 133 256 SL4HE
    1000 133 256 SL4HF
There are 10 types of people in this world:
those who understand binary and those who don't. ~Author Unknown
Reply 61 of 144, by m1919
http://www.youtube.com/watch?v=msQPHxTUgzI
Impressive collection. 😁
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
Reply 62 of 144, by Neon_WA
thx
getting harder to fill in the gaps.. as I collect on speed, cache, voltage & stepping
also I try to have 2 in each group so i can test in pairs
and they not light buggers to ship to Oz
Reply 63 of 144, by m1919
Neon_WA wrote:
thx getting harder to fill in the gaps.. as I collect on speed, cache, voltage & stepping also I try to have 2 in each group so […]
thx
I'm jonesing for a pair of 2.8v 900/2MBs for my XG-DLS. Lol, all I'm seeing these days are 5/12v.
Reply 64 of 144, by feipoa
Wowzers, you are certainly better stocked for this comparison than I am!
Now beginning work on the Cyrix MediaGX.
Reply 65 of 144, by JaNoZ
luckybob wrote:
If I had a nice socket 4 board, I would sit up and watch it all night... I havent even seen on on ePay for a while now. At least not one that is 10x overpriced from that a-hole in canada. you know the one.
ANYWHO... I jsut god done writing a term paper for my sister so I should start benchmarking tonight. I have the 1mb and 256kb pentium pro @ 200. they should run fine at all frequencies. I also have the 333 OD's however their multi's are locket to 5x. so 250, 300,333 are all that can be done. I'm not sure 250 is worth doing. but I will see.
I have 3 the same socket 4 boards (soyo PM900 with intel neptune) with all P66 on them and 48mb edo. i have one p60 but i believe i do not have an 60mhz oscillator to run it, i am not sure if it needs it, have to look for the manuals, have it somewhere at the attic.
I also have a XP6NP5 asus with PPRO200 512KB and a PPRO200 256K
Reply 66 of 144, by feipoa
Can you muster up 64 MB of RAM, and a Matrox Millennium G200 PCI w/16 MB SDRAM? If possible, a Yamaha DS-XG is also the preferred PCI sound card for these tests.
Reply 67 of 144, by JaNoZ
feipoa wrote:
Since there were no takers on the P60/66 (yet!), I've started asking around. I know a non-vogoner guy who may have a board to unload, but he thinks it is in a heaping pile of computer hardware boxes...somewhere. I'm particularly interested if a P60/66's FPU woud outperform the X5-160 in synthetic benchmarks and in Quake 1, particularly because S4 boards tend to be overly sluggist haredware-wise.
Thanks for noting the S-spec. Is there a list of Klamath S-spec's for the 266 variant which are known to be unlocked?
What a S spec.? unlocked? and as for S4 P66's a am5x86 at 3x150 will be on par with the P66 fpu reliant quake wise anyway.
It has been over 12 years now that i used them systems but my Socket 4 boards run like 16.2FPS and the amd 5x86 at 150 does about 15.8 to 16.0 depends on quality of my used ram mostly.
Reply 68 of 144, by feipoa
JaNoZ wrote:
What a S spec.?
http://www.intel.com/support/processors/sb/CS-028738.htm
JaNoZ wrote:
unlocked?
"Unlocked" is refering to the FSB-to-CPU multiplier not being fixed to a specific multiplier on the CPU. Intel, and others, started locking their CPU multipliers at around the time of the Deschutes PII to prevent users from over-clocking.
Reply 69 of 144, by feipoa
This comparison could really use one of these,
http://www.cpu-world.com/forum/viewtopic.php?t=19700
Reply 70 of 144, by luckybob
feipoa wrote:
http://www.intel.com/support/processors/sb/CS-028738.htm […]
JaNoZ wrote:
What a S spec.?
JaNoZ wrote:
unlocked?
not so much overclocking, but people CHEATING, by buying 166mhz parts, labeling them at 200 and keeping the extra cash.
Reply 71 of 144, by feipoa
For those looking for a G200 PCI for this comparison, this listing seems relatively inexpensive for Americans at $7.99 + shipping ($12).
http://www.ebay.ca/itm/370620365835
He does not have G200 in the title, so maybe it will get overlooked.
Reply 72 of 144, by vetz
Another example of a US seller who is gauging on international shipping. 27.25 dollars.. 🤣. Should be $11
Reply 73 of 144, by luckybob
FYI, he is charging $12 for US shipping. But he is the CHEAPEST TOTAL price of other cards. So I really don't understand why you people are complaining. Also he has an option for "make an offer" AND he has taken the time to post lots of pictures. (more than whats needed, but w/e)
Reply 74 of 144, by vetz
Even if he has the cheapest card, doesn't make it OK to gouge on shipping. The link given by feipoa is from the Canadian Ebay site, and here the shipping is 27.25, but if you enter from .com or .co.uk or .de it is 39 dollars. Strange, but that makes it even more unattractive for everyone outside the US.
For Europeans, check this auction out: http://www.ebay.de/itm/Matrox-G200-G2-MSDP-8B … #ht_1432wt_1397
Reply 75 of 144, by feipoa
Agreed, this listing is normally only for Americans. http://www.ebay.ca/itm/370620365835
The issue of high shipping stems from his unwillingness to ship USPS First-Class Mail internationally. I have bought from him in the past, but only when I combined 10 PCI cards into one package. He combined the shipping and that was the only way it was worth it.
One final note on this topic - I have had issues with the G200 cards which have "ASSEMBLED IN CHINA" on the back. It could have been a stroke of double bad luck too.
Reply 76 of 144, by feipoa
Quick Update
I have 1 CPU left to test for this comparison - waiting for a donated Athlon 500 MHz to arrive. 170 CPUs have been tested to date.
Unfortunately, it does not seem like actual test results for a P60/66 or a NexGen will be available. I have had to simulate the data for the P60/66, which is what it would be like on a 430TX board. I suppose it would be 5-15% slower on an actual socket 4 board, depending on the application. CPU-only based tests might be the same though. If anyone has a P60/66 system setup and just wants to run some DOS benchmarks, I'd like to compare them to the values I have acquired.
Hopefully some Xeon results will trickle in this month.
Reply 77 of 144, by luckybob
feipoa wrote:
Quick Update […]
Quick Update
speaking of, it should have been there by now. any update?
On the xeon front, m1919 was kind enough to send me his p2-450/2m ES and a p2-400/512k. However it would appear I have hit a snag when it comes to the motherboard and the only way to describe it is that my motherboard's mother and father, were also brother and sister.
I had my own p2 chip, a 450/512 before all this started bringing my total to three. However in my XG-DLS I cannot run any of the chips in single cpu config. The bios decides that if I'm only going to use one cpu, its going to turn off the L2 cache. No matter which p2 chip I use. the pentium 3's I have, do not suffer this fate. I can swap the cpu and the terminator card in the motherboard and nothing changes.
I decide to leave it for the night and do something else.
next day I start to fiddle with it again, and on a whim I decide to mis-match cpu's and put the 2mb and 512kb cache chips in at once to see if I can generate some sort of error in the bios I can lookup. Well, my little XG-dls was prepared for this. It decides to work perfectly fine. In the splash screen at the end of post before it gets to dos, there is a section for l2 cache. Until now it had been blank. Now It reads; "512kb , 2048kb" I have to admit, I'm rather speechless. I run cachechk and it completes PERFECTLY with 512kb. I swap the cpus, (remember windows 98 and dos are 1 cpu only) and the cache changes to "2048kb , 512kb" and it again, works perfectly in cachechk as 2mb.
by now, i'm convinced the end times are here. Nazi will be riding dinosaurs, the whole lot. In a flash of inspiration (actually I mistook it for the p2-450) I take my p3-550/512kb and slap it in with the p2-450/2m. it boots just fine. Claims both cpu's are pentium 3's but everything still works. I don't know what to do anymore. All my pre-conceived notions about dual cpu's have been shattered. I'm looking out the window for the rapture to begin at any moment...
but seriously, I'm thinking about running the tests anyway in this wonky config and going with it. combined with my p3 chips we should have most results from 400 to 550. enough to make some educated guesses at the missing parts at the very least. 😜 I am however open to suggestions. I cant find anyone with this problem online. and for the record, I've tried 3 different cpu terminator cards and even empty slot (no post).
Reply 78 of 144, by feipoa
Sounds like a complicated mess, but hopefully your numbers will not be skewed.
Yes, Athlon 500 arrived today. It is the last full CPU needed for me to test.
Now that I have figured out how to get OpenGL results for the 486's and non-MMX 6x86 chips, I still have a bit more work to do on this.
Reply 79 of 144, by m1919
When I tried to boot with the single 450/512kb and then the 450/2MB ES, the board wouldn't even post. I had only one terminator board, so I'm not really sure if my XG-DLS just didn't like it or if there was some issue with the terminator itself, but my A-Trend Slot-1/2 board booted with them fine.
