First post, by chii_
I have a bunch of GX110's:
http://support.dell.com/support/edocs/systems … ns/ug/specs.htm
They all have 3 slot PCI riser cards, but I want to replace it with a riser card that has at least one ISA slot for my soundcards!
Are the dell riser cards interchangeable between different models? All of the GX110 boards on ebay right now that have ISA are too big (for the tower models, I have the low-profile chassis models).
If I got a riser board that was the right physical size for my computer would it work, or do I specifically need to find a GX110 PCI/ISA riser board?
e: looks like they're not interchangable between models, but what about getting a tower sized riser card and using it in the low-profile GX110 with the top off?
