I formatted the hard drive so am in the proccessing of installing the GUS again. I thought it was the actual version of DOS causing the crash of the installer but I think it actually has something to do with HIMEM/EMM386. This time round I tried with DOS 6.22 and the installer crashed again. I rebooted and hit F5 to bypass config.sys and it works fine =\.
Sorry back to elianda's question, pnpcfg I have Synth/Codec, Sound Blaster Emulation and MPU enabled. With all of these I receive the error about SB IRQ is either on 7 or in use. I have run the setup program and used the following settings:
UltraSound 220, Ultrasound IRQ 7, SB IRQ 5, Play DMA 7, Record DMA 7. Disabled CD-ROM Bsaeport, MPU401 Baseport 330, MPU401IRQ 9, Disabled Joystick port.
These all tested successfully.
The complete error when I run megam em is:
"ERROR: Sound Blaster IRQ failure. The most common causes of this error are:
- Another device is using the same IRQ as your UltraSound's Sound Blaster/MIDI IRQ. To correct this problem change either your Sound Blaster/MIDI IRQ or figure out which device is in conflict and change it's IRQ.
- You are using IRQ 7. On many systems this IRQ does not work correctly. To correct this, run SETUP and change your Sound Blaster/MIDI/IRQ."
Just to add some more information, if I run MESETUP and leave Roland emulation on but turn of Sound Blaster, MEGA-EM runs fine.
If I only enable SB emulation and disable Roland emulation, I still get the same error.
Not sure if that helps 😁
