First post, by KT7AGuy
- Oldbie
Hi! I'm new to posting here, but I've been lurking for years. I've now got 5 legacy boxes running DOS and/or Win98 with various Voodoo cards. The ABIT KT7A is my favorite board for legacy gaming due to its ISA slot, which I like to populate with an AWE64. I've got two KT7A systems running now, and I'm about to build a 3rd. I recently acquired another KT7A and had it recapped, so I'm getting ready to put this new build together.
About 10 years ago, I bought a couple of Canopus Pure 3D II cards off eBay. Even then, these were quite uncommon. They are both in fantastic almost-mint condition and I even have both of the proprietary pass-thru cables for them. Even better, I even have one of the original boxes with all of the stuff it came with. For a collector, the only thing better would be to have two brand new cards. You can see why I've been reluctant to use them for any of my builds for all this time.
With my new build, I've been trying to decide if I should use the Canopus cards, or if I should try to find a pair of some other Voodoo IIs on eBay. I'm not even sure if these are really collectible or not. I just know they're VERY uncommon Voodoo cards. I almost never see them on eBay anymore.
If I do use the Canopus cards, I'll be removing the built-in fans on them and using some Arctic Alumina thermal epoxy to affix some heatsinks to them for passive cooling. This would render them excellent for me to play with, but completely disfigured from a collector's perspective.
So what do you all think? Should I glue some heatsinks on those Canopus cards and use them? Or, do you think I should try to score some more common Voodoo cards on eBay for my new build?
Thanks for your advice!
