First post, by feipoa
Does anyone have an AMD Am486 DX4-100V16BGC, DX4-100V16*, or any other AMD socket 3 which is a DX4-100 and has 16KB of WB L1 cache? Can you check to see if it is 2x/3x or 3x/4x for the clock multiplier?
The AMD DX4 was more common with 8 KB cache, WB, or WT, however I am inquiring only about the 16KB version of the DX4-100. I would like to know if it has a 2x/3x multiplier option or a 3x/4x multiplier option. The DX5-133's had 3x/4x, whereas the DX4-100-8KB had 2x/3x. So what about the DX4-100 16KB chips? Were they really DX5-133's with DX4-100 markings?
[Note, I also posted this topic at the cpu-world forum, although that crowd generally seems more interested in collecting than testing].
Reply 1 of 35, by BastlerMike
They have the package number 25544, right?
I observed that all chips with this number have 3x/4x multipliers.
There are some later Am486DX4-100SV8B with the 3x/4x multipliers. These chips also have the 25544 number. Contrary to the labeling, they have 16 kB Cache.
Reply 2 of 35, by Anonymous Coward
There is a DX2 66 16BGC of some sort. I recommend that one if you want to try 2x66. It should be the 2X 3X multiplier version you are looking for. Basically the very last DX2, DX4 and DX5 chips were all the same chip.
Reply 3 of 35, by Tetrium
How can this be if they only have 2 multipliers at the most?
I seem to recall this once. I once tested an 8kb chip and it seemed to have 16kb. But iirc this was a DX2-80. I just assumed it was just a strange remarked chip
My retro rigs (old topic)
Report spammers here!
Reply 4 of 35, by feipoa
This AM486 DX4-100V16B doesn't have 25544, it has 25372
http://www.chipdb.org/img-amd-a80486dx4-100sv16b-247.htm
And how can this 25544-marked DX2-66GBC possibly have a 3x/4x? Was anyone running with a 22 MHz bus?
http://www.chipdb.org/img-amd-am486dx2-66v16b … graved-5391.htm
Can anyone test these chips? I don't think a marking of 25544 tells the whole story.
On another thought, I wonder if any tricks can be done to get an AMD X5 3/4x to run at 2x?
Reply 5 of 35, by Anonymous Coward
I can only find mention of a utility to control WT/WB cache.
As far as I can remember all 3V 486DX2 chips (except overdrive) could be configured as 2X/3X. Probably because they were just badge engineered DX4s. Though I am curious about the am486DX2 16BGC, because in theory it should have been a remarked DX5 since no true DX4 was being produced.
Reply 6 of 35, by matze79
I got a V16BGC DX2 CPU 😀
No need for heatsink, stays cool
Reply 8 of 35, by matze79
Yes, had no time to try it 😀
Reply 10 of 35, by Baoran
I was just testing today one of those amd 486dx4 100Mhz cpus with 4x multiplier. One of those that have been marked to have 8Kb of L1 cache but actually have 16Kb.
Anyone knows if I can damage the cpu if I keep it at 4x multiplier instead of 3x long term?
Reply 11 of 35, by matze79
No i had DX4-100 @ 5x86 160Mhz running for at least 2 years until i sold the system.
feiopa, i have currently no board which supports 66/83 which works. i began to rework the Biostar UB8433 but still had no time to investigate what BIOS Chip is used 😀 also missing the content..
on the board it says 271024, but other sources tell me 010 ?!
Reply 12 of 35, by feipoa
I've tested these and they work on the MB-8433UUD: PH29EE010, W29EE011, AT29C010A, and P28F001. The P28F001 is 12 V programming, while the others are 5 V.
Reply 13 of 35, by Baoran
matze79 wrote on 2020-02-11, 09:43:
Do you need to increase voltage to run it at 160Mhz? There is an option for 4V on the motherboard.
Reply 14 of 35, by matze79
No, it runs Stock 3.45V without Trouble.
Its same Core as AM5x86, for satisfying the market. Why produce several different versions if one is enough 😀
Thanks i will try it 😀
Reply 15 of 35, by Deksor
Baoran wrote on 2020-02-11, 09:39:
Same thing here. I tested my DX4s in speedsys when I noticed one of them had twice the cache advertised. So I configured it as a 5x86 and I saw "am5x86 133MHz" 😁.
Reply 16 of 35, by The Serpent Rider
AMD AM486DX4-100SV8B and AM486DX2-66: Interesting observation / CPU relabeling
Reply 17 of 35, by Baoran
Deksor wrote on 2020-02-11, 23:32:
I just noticed today that when it is configured to am5x86 133Mhz with motherboard jumpers and I turn turbo off the system freezes and when booting turbo off it gets stuck at himem.sys testing memory. When turbo is on, everything works fine.
Reply 19 of 35, by Baoran
The Serpent Rider wrote on 2020-02-12, 09:44:
In other words, it's not stable at 133Mhz.
It is stable at 133Mhz. It is when you slow it down using by turning off turbo when there seems to be a problem. I haven't had a single freeze or other kind of problem when it is at full speed.
Not that I would use this kind of computer for speed sensitive games, so I don't need to slow it down. I guess I could try to set the cpu selection jumpers to dx4 and just change the multiplier jumper from that to make it 133Mhz instead of setting the jumpers to 5x86.
