First post, by F2bnp
- l33t
Via and problems, this is the first time I've ever heard of something like that 🤣 .
Okay, so a friend gave me a GA-6VTXE to try out, I had used it for a few hours several months ago, but it was quite unstable. I gave it a though a couple of weeks ago and figured it could just be the capacitors acting strange. I though I would leave it running for a few hours and it would be great!
So, I installed a Tualatin 1.4S, 512MB Ram, Voodoo 5500 PCI and a SB Live!. Win98SE my OS of choice of course.
And as expected things got quite unstable after installing a few things (I think it started right after installing my display drivers). By unstable, I mean soft resets (as if I press the reset button on the case, I can also clearly hear the speaker "click" each time that happens) and occassional hanging.
I know it's not the V5, since the last time I tried it was with a GeForce 4 Ti 4200 and it produced the same problems.
Thing is, the resets only seem to happen when I'm on the desktop. I had the machine running the Demo of 3DMark 2000 for 2 hours, then benchmark for another hour and it never did a reset.
I also left it on the desktop for 6-7 hours doing absolutely nothing and it still never did a reset. I know that because I had left a wordpad file open and it was still on when I checked on it.
The above strikes me as odd. I'd like to try playing a couple of games and see what happens. I'm thinking that the machine becomes unstable with HDD access, perhaps I can narrow it down then. Also, I installed the Via 4in1 Version 4.35 prior to installing anything else, I tried uninstalling it but I'm not sure if it really uninstalled everything. Perhaps I should start anew without installing it (although I'm fairly certain I tried that last time and it made no real difference!).
I'd like to hear some suggestions before I proceed with this. 😁
