Reply 20 of 85, by Great Hierophant
- l33t
Windows 95, all editions, does not support drives larger than 32GB by design :
http://support.microsoft.com/kb/246818/EN-US
While Windows 98, FE or SE, does not have a strict hard drive limitation, it will not partition disks larger than 64GB properly without the hotfix installed from here :
http://support.microsoft.com/kb/263044
Even with the hotfix installed, it is not supported for drives larger than 137GB, the 28-bit LBA limit. I would extract the format program from the disk and put it on a boot disk and partition a new drive from it. 7zip can open the exe, just rename the file with the extension 98g or 98s.
It will also not display the drive size correctly when the format command is run in DOS, but will format the disk properly even if it is larger than 64GB :
