First post, by sirlemonhead
- Member
Hi,
It looks as if my S3 Trio from my Pentium 1 has died 🙁 no video output at all from it anymore. It's definitely the card as the machine runs fine with a PCI TNT 2 that I have.
I guess I could leave the TNT 2 in there.. I know it's overkill but I really have no other use for the card..but is there anything that'd be better than that for this machine? Just for DOS games (Doom 2 and early FPS games mostly) - Which would have the best image quality etc?
Also, is it generally a bad idea to plug in VGA cables while the PC is powered on? I've been doing this for 20 odd years without issue but i'm aware that voltage does go down the VGA lines.. Otherwise i've no idea what happened the Trio 32 card 🙁
