First post, by northernosprey02
Can I plug old S3 Trio64V2/DX PCI to my computer which it has newer motherboard? The motherboard has PCI slot
I have do them for testing
PCI should be always safe.
I think only the reverse (newer PCI card on an older mainboard) might give problems, but it shouldn't damage anything.
The one time I saw this was with an ASUS P55T2P4 and some early PCI Radeon (7500?). The card ran fine in another SS7 mainboard.
I mean S3 Trio64V2/DX on ASUS P5KPL-AM SE G31 LGA775 mobo. It is work?
The problem is going to be which OS are you running in the test system? A very old video card may not have a driver for the newest operating systems.
Physically - yes, all PCI versions except 3.0 are using 5V PCI slots.
The trouble is - PCI 2.3 is using the old slot but isn't compatible with the old (2.1) cards.
So - check the PCI version of your's MB first.
Alright, I just plugged the old S3 Trio64V2/DX on my ASUS P5KPL-AM SE LGA 775 mobo and it's working fine! But I don't do boot to windows, I have to stop to BIOS setup.
