First post, by PowerPie5000
- Oldbie
I'm thinking about getting a cheap ATA 66/100 PCI IDE controller as my SE440BX-2 board only supports upto ATA 33 (and the HDD it's using is either 66 or 100) . I've heard the Promise cards are good and most of the VIA based cards are bad (apparently many of them are not bootable).
Can anyone recommend any models or specific chipsets to look out for? I only need it for the HDD as it seems many don't support booting from a CD/DVD drive (so i'll leave that plugged into the mobo). It definitely needs to be able to boot from a HDD.. I understand i change the boot device to SCSI within the bios?
