First post, by rgart
The output connection of this card is not VGA or DVI... What is it? Matrox have there own standard?
Do I need one of these:
http://www.ebay.com.au/itm/Matrox-CAB-L60-2XD … =item4d044afda6
Reply 1 of 2, by Old Thrashbarg
It's called DMS60. It'll also take the DMS59 cables that Dell and other OEMs like to use. (The only difference between DMS59 and DMS60 is that DMS59 has a missing pin, which isn't used for anything on DMS60 anyway...)
Reply 2 of 2, by NitroX infinity
Matrox' MMS cards are for multi-monitor output. As you can see, the cable for it splits into two outputs.
NitroX infinity's 3D Accelerators Arena | Yamaha RPA YGV611 & RPA2 YGV612 Info
