First post, by vintagegames
Hello,
I am looking to integrate my vintage gaming PC (GA-5AX) with two of my modern computers via a KVM switch. All of them have DVI ports and I am using a 1920x1200 display.
Naturally, I find plenty solutions for either USB or PS/2 connectivity. There are some with both, but like the pure PS/2 ones they usually have poor DVI resolutions (even below what single-link is capable of).
Also, I am unsure even from the manuals if USB keyboard/mouse to one PS/2 computer will actually work (I have inquired with the manufacturers, I am quite curious to see what or if they respond).
Regarding USB to PS/2 adapters, I only find the ones for re-using PS/2 keyboards and mice - what I'd evidently need is the other way around.
These are my current KVM switch candidates:
http://de.level1.com/Desktop-KVM-Switches/KVM-0306/p-344.htm
http://www.digitus.info/en/products/datacom/k … ort-dc-11801-1/
Ideally, I'd just get a really up-to-date KVM switch and add an adapter (which I would be willing to spend the odd $50 on if it works).
I might also spend some amount on a full switch and just use it to switch the input devices - if that work without connecting the display.
Another alternative might be to get a USB switch and combine it with a converter (i.e. leave out the video again). However, the products I see all presume each PC has its own input devices and you just want to share scanners or printers.
A general concern is if switches or adapters put at least the mouse wheel through to PS/2 (and the rest of my buttons to USB, of course).
Does anyone have a suggestion (or better, a similar running solution)? In the forum I didn't really find much with "usb and ps/2" or "kvm" - or rather I found too much).
Going through forums and reading through actual product manuals, I get the usual feeling that I'm the only one with these specific requirements for my vintage gaming platform.
I know I am asking a lot, so please only feel compelled to reply if it's sort of an "easy answer" for you. 😀
P.S. I made mixed experience with USB emulation on the PC, particularly for the mouse. I know there are DOS USB drivers, but I would actually prefer a hardware solution.
