First post, by Pingaloka
- Member
Hello hello. I've been playing with an 486 for a while.
Checking different CPU's doing different benchmark tests.
Checked Am5x86 133mhz, 486 DX4 75mhz....
I'm interested on playing 90-97 era games. So I decided to make a 2nd gaming rig and keep the 486 as a true period piece for early 90's games. I decided to have a 486DX2 66mhz CPU and give up the idea of having an almighty powerful 486.
The 2nd computer is going to be a Socket 7.
Motherboard: Abit PR5 R2 PCI
Case: Just got it today! Really nice case that will match up the 486 one. Here's a picture of both.
486 Case
CPU: Actually I'm going to use a Powerleap PL-ProMMX Plus adaptor I bought from Japan (Yes I know, it would have been easier to just get another socket 7 board) with a 233MMX or an AMD K6-2
So the big question comes up. Which CPU should I use?
From what I've read the AMD K6-2 has some advantages over the Pentium 233MMX, like 3DNow! technology. But would this board really take advantage of the AMD K6-2 CPU in comparison to the MMX one?
Here are the MOBO specs:
http://stason.org/TULARC/pc/motherboards/A/AB … ml#.UZaXBopdVMi
Also the powerleap adaptor supports Clock Multiplier from 1.5x till 5.5x
