First post, by EverythingOldIsNewAgain
So I'm a long-time lurker on this site. The idea that there are other folks out there that get sexual pleasure (OK maybe not to that extent) from old PCs and old games makes me quite happy.
Unfortunately my first post on here is a quest for help for a problem that's perplexing me. Driving me crazy is more like it. Also it's not that old. But I figure you all are a good one to throw it at -
I have a Dell Inspiron 4100 (I believe this also goes by the name Latitude C606 - and it's rebadged). I bought this system as a shell (no hard drive, minimal RAM, no AC adapter). But it was said to be working. And it is - to a point.
So I added a hard drive and installed the Intel INF drivers, Intel ATA driver, NVIDIA driver, and Windows XP SP3 (& all post-SP3 hotfixes). All went well until the system randomly locked up. A hard lock up. No BSOD, no event log, no memory dump. This has happened several times. Sometimes days go by and there's no real pattern.
So I first verify temps. They're all running fine, nothing that hot. Indeed the system is rather cool to touch and the fan spins on only occasionally.
I downloaded HDSentinel and tested the hard drive. It's a brand new drive and as expected it tested OK, no errors, SMART OK, surface scan fine, etc.
I ran Prime95 both in "blended" and "large FTT" modes overnight and got no errors.
To "torture-test" the GeForce2, I ran 3DMark2000 in a loop overnight. Again, no errors.
I ran HCI Memtest to 1,000% coverage and also received no errors.
OK, this is starting to annoy me. And then I notice something perplexing - the system is not running at the rated clockspeed. It has a 1.2GHz Tualatin P3-M but it's stuck at 900MHz. "Aha" I think...maybe power management is screwing it up?
But after fiddling with the BIOS I realize, no the system is throttling normally. x9 is the normal multiplier and that's what it runs at under load (x6 not under load). But the system is only running at 100MHz FSB. It should be 133. If it was running at 133 it'd be roughly the rated 1.2GHz.
So is the RAM messed up? I tried memtest86 from boot CD and it failed. That is it just froze at the blue loading screen. Running it in diagnostics mode found that it fails at "get_spd_0". OK, lets try new RAM. So I put a brand new Kingston 512MB PC133 SODIMM in it.
Results...
-Still stuck at 100MHz FSB
-Memtest86 won't run, but HCI MemTest in Windows runs OK with no errors.
-RAMMON fails with "couldn't get SPD information"
-CPU-Z reports only SPD information for DIMM2 but not DIMM1 (when there are two DIMMS). If I only put the DIMM in DIMM1, I get no SPD information in CPU-Z, but the memory shows up and Windows "works".
Tried (yet) another (brand new) Kingston module (256MB PC133) same results.
What am I doing wrong? What is wrong? This is driving me nuts.
Specs -
Dell Inspiron 4100 BIOS Update A13 (latest, circa 5/2003)
Intel 830MP / ICH3-M Chipset
Intel Pentium 3-M 1.2 Tualatin-512 (running at 900/100FSB for some ungodly reason)
Tried with three different RAM modules (two Kingston PC133 SODIMMs - 512 & 256, & 1 Samsung 256MB PC133 SODIMM)
40GB Toshiba HDD
GeForce2Go 32MB DDR AGP
Cisco AiroNet 802.11g WiFi (CardBus)
Windows XP Pro SP3 w/ post-SP3 hotfixes
Intel 800-series INF, Intel Application Accelerator 2.2.2, & NVIDIA 93.71 WHQL drivers
Many thanks in advance!
