MS-DOS PCI SATA Controller - Weird issue
Reply 41 of 81, by carlostex
Here we go:
ACPI Function moved to the right side of the screen.
    5AX1.zip
    113.17 KiB
    49 downloads
    ACPI enabled BIOS
Reply 42 of 81, by Mau1wurf1977
Well look at that 🤣
Now I just got to pull out the PCI SATA card and confirm that Gateway doesn't hang!
Also I have attached UNIFLASH and the AUTOEXEC.BAT I use for blind / input free flashing.
    UNIFLASH.zip
    45.74 KiB
    48 downloads
    UNIFLASH.EXE and Autoexec.bat for blind flashing. Just place the BIOS file on the floppy and change the file reference in AUTOEXEC.BAT
My YouTube channel
Reply 43 of 81, by keropi
great read so far!
I was lucky that the 591p has the ACPI option by default, it solved my MPU problems...
Mau1wurf1977, if it works you should probably leave an overnight memtest running just to ensure that the bios mod didn't break anything... 🤣
Reply 44 of 81, by carlostex
F**K YEAH!!!!
Finally.
I bet it was MODBIN version. Awesome.
Now yes, you do gotta set that Roland MPU-401 on IRQ9 and see if ACPI is still there or not. There's always the possibility they hid ACPI because it couldn't be disabled anymore.
Reply 45 of 81, by Mau1wurf1977
Bad news 😒
The game still hangs when run from the SATA drive. Works fine from the IDE>CF drive like before.
So it appears the setting doesn't actually do anything.
My YouTube channel
Reply 48 of 81, by Mau1wurf1977
Yea quite bummed...
Ordered two BIOS chips for the AOpen board. Unlike the others it uses a 2 Megabit flash chip and I don't have another one. Hopefully the board is still ok 😒
EDIT: Are you sure the IWill has an ACPI setting? I'm quite sure it doesn't...
Might check quickly...
My YouTube channel
Reply 49 of 81, by carlostex
Mau1wurf1977 wrote:
Yea quite bummed... […]
Yea quite bummed...
Latest BIOS has it enabled!
Reply 50 of 81, by Mau1wurf1977
Dang I'll check it out right away 😀
One thing about the IWill, the FDD and IDE headers have ALL the pins. So newer cables won't fit. Just a little detail.
What is good about it though: FSB adjustment through BIOS! Absolutely terrific.
What BIOS version have you got for this board?
The one I use I have attached in this old thread: Super Socket 7 - VIA MVP3 or ALi Aladdin V?
My YouTube channel
Reply 51 of 81, by Mau1wurf1977
OMG it does. It's in the bottom right corner. I never saw it and it was there all along 😵
Will test the PCI SATA card right away with the setting on and off...
My YouTube channel
Reply 52 of 81, by carlostex
Mau1wurf1977 wrote:
Dang I'll check it out right away :) […]
I think i have enough cables to get away from that problem.
Yep, changing FSB through BIOS is awesome. Almost as awesome as my QDI Titanium IB+. AT Board, very advanced. I believe it is the besy AT S7 board ever made. Rock solid. Does not support 100MHZ FSB though. But allows to change core voltage, multiplier and FSB on the BIOS, no jumper configurations at all.
EDIT: One of the things i like in the IWill or DFI is that you can assign IRQ by individual PCI slot.
Reply 53 of 81, by carlostex
Mau1wurf1977 wrote:
OMG it does. It's in the bottom right corner. I never saw it and it was there all along :dead: […]
I'm modding that BIOS as we speak!
EDIT:Removed the file as this MOD rendered the board very unstable.
Will upload stable version below!
Reply 54 of 81, by Mau1wurf1977
Ha that's cute.
Well looks like 2 of my 3 SS7 boards have that ACPI switch.
Dang. I think I will have to revisit my "Ultimate Time-Machine Project" and report about these findings...
A project for my next holidays though, nothing in the near future...
Also the IWill board couldn't blind-flash. It wouldn't boot from the floppy, whereas the 5AX did just fine. Interesting these subtle differences...
My YouTube channel
Reply 55 of 81, by carlostex
I'll be waiting. 😎
BTW, does Gateway lock up with PCI SATA controller on this board?
Reply 56 of 81, by carlostex
IWill XA100Plus MODDED BIOS STABLE.
This BIOS has been personally tested by me and it's working very well, but as always:
USE AT YOUR OWN RISK!!!
    XAP1027.zip
    129.44 KiB
    46 downloads
    IWill XA100Plus ACPI modded BIOS.
Reply 57 of 81, by Mau1wurf1977
What have you changed?
I got a new case coming with 2x 3.5 and 4x 5.25 bays.
Then I saw an image of an old AT tower which had 2x 2.5 and 6!x 5.25 bays 😵
But in the ATX size it seems 2/4 bays is the most one can hope for.
My YouTube channel
Reply 58 of 81, by carlostex
Mau1wurf1977 wrote:
What have you changed? […]
I had activated all the stuff that was hidden. In the new version i pretty much just made ACPI sit in a new position and something else i can't remember. Anyway it's stable as a rock now!
A case with 2/4 bays? I'd say that's more than enough! Actually that would be perfect for me. I had to remove my SATA drawer to accomodate my internal ZIP drive which comes very handy at times. A ZIP is much more reliable than floppies, is fast enough and has more than enough space to carry data from one machine to another.
What ATX case/model are we talking about?
