First post, by badmojo
I have a revision 2.1 version of a VL/I-486SV2GX4 Motherboard, which includes multiple options for CPU voltage - see the spec below for details. The board came with a DX266 Overdrive chip on it and it all works fine, but the relevant jumpers (32 and 33) are set to the 3.45 volt setting. How can that be? Is the spec wrong, or will a 5 volt chip just draw as much as it needs regardless?
Also, the spec doesn't include a 5 volt option - it only goes up to 4 volt. Does that also indicate that the spec is wrong?
http://www.motherboards.org/files/manuals/1/C … I-486SV2GX4.htm
Reply 2 of 5, by vetz
As far as I know the DX Overdrive CPU's run at 3 or 4 volt. I own this motherboard myself (it is the best 486 board I own) and I don't believe there are any 5V option. I know the Overdrive CPU's are made for running in 5V boards, but I believe when used in a 3v board it bypasses the voltage regulator. Same happens with the POD5V83 (which I use in this mobo)
See picture of the chips here:
http://www.chipdb.org/cat-dx2-66-331.htm
Reply 3 of 5, by 5u3
Many socket 3 boards autodetect the required voltage through the VOLTDET pin.
Reply 4 of 5, by badmojo
OK thanks for the replies. Mine's the SZ935, dunno where I got the idea it was 5 volt from, but I wouldn't be surprised if I was wrong. Seems like these things are truly "plug and play" though - that was the idea I suppose. Intel had a winner on their hands with the Overdrives, they must have sold truck loads of them.
Reply 5 of 5, by viktorcech
this is best MB for 486? i looking for something best
