cdoublejj wrote:what are the specs on that beast?
It is 2004's midrange gaming notebook favorite, the eMachines M6805 / M6807 / M6809 / M6811 / Gateway 7422GX / Arima W730-K8. It's a DTR essentially so it is a bit heavy.
15.4" 1280x800 LCD
Mobile Athlon 64 3400+ (2.2 GHz)
VIA K8T800 + VT8235 chipset
ATI Mobility Radeon 9600 64MB (300/200 MHz clocks)
2GB PC2700 RAM (one slot is buried inside)
100GB 7200RPM HDD (limit is 120GB because of the BIOS)
DVDROM
Broadcom 802.11n Wifi (I found an N card for it, was originally G)
VIA Rhine 10/100 ethernet
Realtek ALC201 audio (has 98 support)
I don't know if I suggest looking for one. They tend to have a LCD backlight flickering problem because of poor connectors inside. You can fix it but it's annoying. The plastic lid also inevitably develops superficial cracks near the hinges. Ugly but it doesn't matter.
The Cardbus slot is cool and you can of course use the Audigy 2 but the ENE cardbus chip and the Radeon don't get along and you get PCI latency problems (audio issues).
Notebooks always seem to have a bunch of issues you don't notice at first though. This thing is almost 10 years old and I still use it occasionally. I've put Win7 and 8 on it but XP is really the best choice.
