First post, by Dant
- Member
After the commentary I made on one of the old 'Sound Card Compatibility' threads on PCI based cards, I've done quite a bit more research and am now prepared to do some experimentation with Mini-ITX rigs and DOS/Win9x. I plan on making one build specifically for DOS, and one build for GLide compatibility, after which I will test performance on the CPUs with the boards I'll have and attempt (attempt) to provide some info on the viability of VIA and Geode CPUs/motherboards for our purposes.
Now, for the 3DFX build in question, I plan on using this: http://www.ebay.com/itm/VIA-EPIA-800-VIA-C3-8 … =item3a8305d7bf motherboard, and want to use one of the Obsidian 200SBi's stil on eBay for the secondary GPU in the build. I have confirmed the onboard audio is SBPro compatible. (If it doesn't in the end... I have a backup plan that I know will work.)
Now, though before I make any purchases I need to locate where I can buy a medusa cable so I can complete the build... anyone have any ideas? It's not an imperative, I can just slap this Intergraph Voodoo Rush into the build and call it a day, but I'd like to maximize the build.
