First post, by Totempole
- Member
Hi everyone,
I want to connect 2 monitors to my Radeon 9700 through the the VGA and DVI outputs.
The thing is, I don't want to use it as an extended desktop, but rather a second screen
with exactly the same output. So 2 monitors displaying exactly the same picture.
Is this possible? If yes, what settings would I need to change in order to achieve this?
I recently just bought a VGA splitter in order to achieve this, but both outputs become
dull and washed out, most likely due to power output of the signal being split in two.
I'm sure a powered splitter would work, but they're unnecessarily expensive, so I don't
want to go that route.
Any advise would be much appreciated.
Thanks. 😀
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
