First post, by ibm5155
The Game Theater only support 16mb of edo ram, and I have here 32mb edo, so, would this 32mb works fine? (It wouldn't be a problem for me if the 32mb was used as a 16mb memory, I just want it could be compatible with the board 😀
Reply 1 of 3, by Old Thrashbarg
Well, if you have the card, and you have the RAM, just pop the stick in there and see what happens. Even if it doesn't work, it won't hurt anything to try.
Reply 2 of 3, by Skyscraper
32mb EDO ram detected beeeeeep commencing self-destruct sequence beeeeep 😁
Reply 3 of 3, by ibm5155
Wow, I got scared, I think I had lost my wavetable D: (at least the fm synth is good)
well, so now I leaned the lesson, sound cards are not equal to motherboards where you can put a memory higher than the supported '-'
