First post, by snorg
So I decided to finally do something with this retro box of mine, I have several more modern OSs but no way to get them on this system (no CD-ROM). I do have a floppy disk drive but no floppy disks around anymore (may be some at the parents place but not sure I want to trek out there).
I have a working Pentium Pro 200 system with a CDROM drive, and also an old school 100MB parallel port zip drive.
Now I could probably copy win95 or OS/2 to a zip disk, but of course won't be able to boot from it. Would it be possible to install from it? I'm not sure how that would work, and if it did it might be slow as hell.
I could temporarily hook a CD ROM to this PC and just set it outside the case, that might work best, but there is no way to stuff it in the case.
As far as OS, what would you go with? I'm leaning towards OS/2, but Win 95 would probably be less headache. I'm not sure Win 98 will run well on 486 era hardware, but I also have access to it. No way am I going to try and put Millenium or Win 2k on this system. I have 16mb of RAM and I believe 256k cache so 95 should run ok, also OS/2 warp if I can get around the CDROM issue. What do you guys think?
