First post, by Mau1wurf1977
Hi all!
Got a bunch of ISA controller cards and encountering something weird. The GoldStar (5 cards) and UMC (2 cards) cards all work, but NONE of the Winbond cards.
Now this is odd and likely I'm missing something obvious, maybe a jumper setting but I couldn't find these cards on Jason.org or anywhere else. I assume many of these cards are very similar in terms of how the jumpers work, so maybe someone can help?
Working cards:
Cards not working (FDD POST error)
My YouTube channel
Reply 1 of 13, by stbunny
Hey, I've got some jumper settings for Prime 2C. Hope this helps.
P55T2P4, Intel Pentium 133MHz, 32Mb EDO, S3 Virge 325, YMF-719s + SC-55, AHA-2940U2W, ST39175LW, UltraPlex40Max, Opti USB PCI, Sony CPD-G400P 19"
Reply 4 of 13, by JaNoZ
Maybe the winbonds are jumpered default to a different ide adress, and therefore a 286 bios does not find any ide controller attached at its different adress.
Reply 5 of 13, by Mau1wurf1977
That's possible, but where do I start 😀
My YouTube channel
Reply 6 of 13, by kixs
Just a few days ago I discovered my Winbond I/O controller "died". It worked fine 10 month ago. Now it also gives error about FDD and/or HDD controller at POST. 🙁
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 7 of 13, by Zup
I remember frying up a floppy controller (it was a Winbond VLB card) in my 486. I forgot that I was making a backup (using a QIC80 tape drive) and wrote some data to a floppy at the same time.
After that, the floppy controller showed errors every time the computer was cold, but it worked after some time warming up. Maybe some of your cards needs some warming (or not).
I'm selling some stuff!
Reply 9 of 13, by colpoz
Hi Phil,
do you remember if in the end you were able to make the winbond cards work?
I'm thinking about getting one for my 486 but after reading this thread I'm not very sure ...
RetroPc I: Asus P3V4X - PentiumIII 1000MHz - 256MB Ram - Geforce3 Ti 200 - SLI VoodooII 12MB - Aureal Vortex2 - HDD 80GB - Win98 SE
RetroPc II: Asus P5A - K6-2 333MHz - 64MB Ram - Geforce2 MX - Voodoo 4MB - Soundblaster AWE64 - HDD 13GB - Win95
Reply 10 of 13, by sf78
I have to say I had similar results with a couple of these. I used hours to check everything, but there were these 2 card that I couldn't get to work no matter what I tried. Same problem with POST giving FDD/HDD errors.
Reply 11 of 13, by colpoz
And did you also have others Winbond cards that worked? Or just these two?
The question is if these Winbonds are extremely easy to die or they don't work on some systems...
Reply 12 of 13, by Jinxter
Mau1wurf1977 wrote on 2013-12-03, 12:03:
I have the same card and cannot boot from it. (have not tried floppy).
I found the Jumper settings here: https://stason.org/TULARC/pc/hard-disk-floppy … -KING-PUZZ.html
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
X: https://x.com/Retro_Erik
Reply 13 of 13, by majestyk
All I can say is the Winbond "W83757F/AF" chips die very very often. I just replaced 3 of them on 3 different mainboards.
New old stock W83757 are nearly impossible to find today and I think I know why...
