Reply 20 of 24, by Malik
- l33t
I have the CMS chips installed on my SB CT-1320 card. It does not require any CMS drivers. I have played The Colonel's Bequest (Sierra's Laura Bow 1) using the CMS/Game Blaster option, and it plays well.
That's the beauty of this card. It does not require those drivers to function. Not until the advent of SB16, that you needed to load so many memory consuming drivers foe the cards to function.
The only reason that you may want to use the installation disks is to copy the Creative's software like the Talking Parrot, Dr. Sbaitso, FM Organ and the dos CMF player. And it also copies the said TSRs (sbfm, etc..) and the ct-voice directory.
IIRC, the setup will only place the SET statements in the autoexec.bat file.There won't be any TSRs loaded or placed by the setup.
Edit: I don't remember seeing a "CMS driver"...
