I don't see the point of investing in a multi-processor system unless that's exactly what you need. Building with legacy multi-processors is both expensive in terms of the sum total invested in the equipment and the subsequent power use once to get everything up and running.
If this is for something basic like a Minecraft server, my recommendation is to purchase as many cores as you can on a single processor, as your power bill will make up the difference in cost.
You can pick up a Supermicro H8SGL-F fairly cheaply on ebay and, if you're really lucky, nab one with a processor in it too. There is one up on ebay with an 8-core Opteron for less than $300: http://www.ebay.com/itm/181265649319
Keep in mind that if you want to drop a 16-core Opteron into one of these you will need the bios to be updated. This means that you will have to confirm that it has the latest bios BEFORE you buy or make sure you buy one with a bundled processor so you can do the update yourself.
Xeons are nice but Opterons are the way to go if you want to build a cost-effective server. That's what I did and it's running great on CentOS 6.4.
Also note that most boards don't come with a heatsink and the ones that do run extremely loud. Here is a fantastic G34 heatsink that's nice and quiet:
http://www.newegg.com/Product/Product.aspx?It … N82E16835608023
