First post, by badmojo
On paper the Jazz16 sounds pretty good to me, with real OPL3, a wavetable header (on some of them), SB Pro / Adlib compatibility. Does anyone have any experience with this card? The '3D Pro' version that came with the Korg daughter board would have been great if it did what it claimed.
There are a few on eBay but none with a wavetable header - I see no reason to buy one without it.
Reply 2 of 34, by bristlehog
Cloudschatze once said that Jazz16 chipset has flawed DB header, I don't remember what's the cause, he might clarify this.
Hardware comparisons and game system requirements: https://technical.city
Reply 3 of 34, by badmojo
Hmm I think there's a rare-ish version of the PAS16 out there with a flawed DB header, but I don't think the Jazz16 suffers from this. They wouldn't have gone to the trouble of pairing them with a korg DB if that was the case, I don't think?
Reply 4 of 34, by bristlehog
Meanwhile in Canada...
Meanwhile in USA...
Prices are ridiculous, however, I think you might be able to haggle down to some $30 or whatnot.
I've also found something about Jazz16 DB flaws.
Reply 5 of 34, by orcish75
Yup, I had the Pro 3D version with the Korg wavetable board way back in 1996-ish in my AMD DX4-133 setup. I remember it was VERY expensive back then and saved up for months before I could buy it. I certainly don't remember any hanging notes on that card and it's SB-PRO compatibility was top notch. It did have one glaring issue that made me return it and get an AWE-64 Gold instead. When playing 16-bit audio, the one channel (can't remember if it was left or right) was quite badly distorted. I remember being bitterly disappointed playing any Direct X games, Diablo, Starcraft, etc and having distorted music coming from the one channel. The same thing happened when playing MP3s. The other channel was crystal clear. It never had this issue when playing 8-bit audio in DOS games, both channels were clear and distortion free.
I did all the usual testing, bypassing the volume control knob and amplifier section, changing drivers, putting it into a different machine etc, but nothing helped. I finally gave up and returned it.
Reply 6 of 34, by badmojo
bristlehog wrote:
Right you are, when will I learn not to argue with the experts?
Thanks for the links, I'll throw in an offer and see what shakes loose. I'm not paying anywhere near 80 bucks though!
Reply 7 of 34, by badmojo
Yes I vaguely remember someone saying once that Media Vision audio cards didn't play nice with Windows games, and that they should be considered DOS only.
Reply 9 of 34, by Cloudschatze
I own two "Pro Audio 3D" boards, which consist of the "Premium 3D" board combined with the Korg, "Pro Wave" DB. It's a pretty decent card, in my opinion, and I know that Trixter has some nostalgia for it as well.
The Premium 3D, with its Jazz16 chipset, builds upon the PAS-16 line by offering SRS sound-enhancement technology, a "supported" WaveBlaster header, Sound Blaster Pro (2) digital/FM support, a faster SCSI chipset (on the SCSI model), and support for VESA's VBE/AI sound standard initiative.
There are a few pretty big caveats to consider though, in my opinion:
- The Pro/Premium are not backwards-compatible with the PAS/PAS16
- The Pro/Premium are not mixer-level compatible with the Sound Blaster Pro
- There's no 16-bit digital playback in DOS outside of the VESA driver interfacing... which almost no software supports. (Way to go, MV!)
With Media Vision's follow-up product, the "Deluxe," the MVA-508B mixer chip is replaced with the MVA-514, which is less feature-rich, but fully SBPro mixer-level-compatible. SRS is dropped, however. I don't own one of these, inexplicably... 🙁
Logistics wrote:
Were the PAS 16's Full-Duplex cards like the AWE32?
Yes
Reply 11 of 34, by bristlehog
One more Jazz16 with DB header (MCD version), from $25, BIN $35, USA.
Also, there's a suspicious PAS16 with two 26-pin connectors, however, without pins soldered. It could be that DB-enabled PAS16 Cloudschatze mentioned.
Reply 12 of 34, by badmojo
Thanks mate, shipping was reasonable and it looks to be in good condition, so I bought that one. A little x-mas gift for myself. And yes it looks like the "Deluxe" model mentioned by Cloudshatze - I don't need the SRS stuff anyway, I have an external module for that!
I'll report back once I've given it a try.
Reply 13 of 34, by Cloudschatze
Well, so the card that *would* have been the Pro Audio Studio XL, when combined with the Pro Wave DB, is the 650-0097-xxx model, which looks like this:
There are two of these on eBay right now.
That's not an actual Media Vision card, I'm afraid, but it should be functionally equivalent to the Deluxe. You'll have to let us know how the Sound Blaster Pro support fares.
Reply 14 of 34, by badmojo
Oh crap, so what did I just spend 50 bucks on?! A licensed clone?
How embarrassing.
Reply 15 of 34, by bristlehog
Oops, it seems you bought an OEM card by KTL. Sorry for misleading you, I should've checked the FCC ID, for MediaVision it usually starts with IXW, not KRN.
I myself have a KTL OEM card based on Aztech SG NX Pro series: picture. Works like a charm though.
Reply 16 of 34, by badmojo
No worries, I should know better by now - it clearly says 'made in China' on it. Never mind, the more sound cards the merrier.
I'll have to buy myself another xmas gift now though 😈
Reply 17 of 34, by bristlehog
Grabbed one. How does it go against an IXW-PAR? I can see that IXW-PAR has an extra connector, but which one has better signal shielding?
Reply 18 of 34, by Cloudschatze
I haven't done any A/B tests between the two, I'm afraid, but the fact that the MVA-508B mixer chip integrates a substantial number of external components that are present on the Pro Audio Studio boards would suggest better output quality. I recall the OPL3 whine being a lot more prominent on the "XL" boards, however...
There are a few things to note about the card you just bought. If you want to use a full-size DB, you'll need to reposition or replace the crystal oscillator for the Thunderboard chip. I suspect Media Vision intentionally used a crystal that obstructs the DBs in order to discourage use of the WaveBlaster header. The software-mixer support for the DB header on this board is also, eh, interesting - you'll need to change its volume through use of the "PC Speaker" slider.
Enjoy. 😀
Reply 19 of 34, by badmojo
My fake Jazz16 showed up (bought here: http://www.ebay.com.au/itm/221334905130) and a) it's not the one pictured (same card, but not as clean and has some minor dings) and b) one of the little capacitors seems to be corroding. It installed OK (after I worked out that the MPU-401 had been disabled via a jumper), and the SB Pro / FM seems good in the few games I tried, but the wavetable header only worked in DOOM and nothing else I tried (Duke3D, ROTT, Daggerfall). Whether this is because the card is bad, or because it just has crappy MPU-401 functionality in general is anyone's guess.
I don't want to waste any more time on this disappointing piece of shite - I've messaged the seller and asked for a refund. This chipset has potential still I think; perhaps I'll try again one day, but with a real Mediavision card next time.
Sigh.
