First post, by Robin4
- l33t
I like to have an discussion about voltage regulators. Because most boards from the 486 till later have them to convert an input voltage to an lower output voltage..
Iam not very technical about electronic components, and really want to learn how those things work.. I already looked for some data sheets and compare those thing to each other..
Most 486 boards that i find are really lacking those voltage regulators, so the most will only work with the 5volt processors.. I know there are interposer boards that would do the converting the voltages. But i really want
to use those interposer board only as plan B.. if there is nothing do about it.
For motherboard there are different kind of voltage regulators.. The populairs are the LT1085 and the Sharp PQ30RV21. The first is an 3 leg type, the other is an 4 leg type..
What i know about those is, that the 3 leg type uses an other output channel (so this type needs to connect to the board it self, the 4 leg type wont i guess..
What are te other differs from both types? I guess the 3 leg is an older one and de 4 leg is the newer one?
I also have here an:
(ADI) TK-8498F/GP 4ND24 motherboard and when i bought this board, there wasnt any VRM installed on it.. So when i red an manual i found they said it would be possible to solder an LT1085 in.. But actually that seems dont doing the job.. Iam also missing resistor R55.. And maybe an other component to.. I really like to have this job done on this motherboard.. This motherboard support above both voltage regulators, the three and the four pin.. Because iam not very good in math, i can decide with resistor i need to solder in..
