First post, by TELVM
This is an old style mobo, from the times before the "P4" connector, so all VRM caps are identical 6.3V 1500uF:
file.php?mode=view&id=243715
The left pair in particular have to hold a difficult position, surrounded by coils and unsunk mosfets. They soldiered on for more than a decade but finally succumbed to the murderous heat, gave up the ghost and bloated:
file.php?mode=view&id=243716
So a full recap was on the order.
- VRM: 7x 'M' (unknown cheap brand) 6.3V 1500uF 10mm ==========> 7x Nichicon HM 6.3V 3300uF 10mm
- Smaller caps: 10x D.S. 6.3V 1000uF 8mm =====================> 10x Panasonic FR 6.3V 1000uF 8mm
file.php?mode=view&id=243717
file.php?mode=view&id=243718
file.php?mode=view&id=243719
file.php?mode=view&id=243720
file.php?mode=view&id=243721
file.php?mode=view&id=243722
file.php?mode=view&id=243723
file.php?mode=view&id=243724
file.php?mode=view&id=243725
file.php?mode=view&id=243726
The preceptive homebrew heatsink for the mosfets (slice from old Athlon XP heatsink 😀 )
file.php?mode=view&id=243727
Finally I thought about replacing the thermal paste under the northbridge heatsink, which surely would be dry and tired after more than a decade. But my worries were unfounded, for ...
file.php?mode=view&id=243728
... there was never any thermal paste at all! A pea of Artic Silver 5 and back to its position it went.
Restored 440BX mobo with slocket Tually 1400-S inserted, in fresh combat order for a couple more decades of zombie-crowbarring in Half-Life 😎 :
file.php?mode=view&id=243729
Let the air flow!
Reply 2 of 9, by PeterLI
Cool! How much time did this take you to fix all this? 😀 Too bad you live in ES: I have a MOBO that needs to be diagnosed/fixed. 😵
Reply 3 of 9, by Skyscraper
That looks great
I should order some new caps.
I have the bad habit of only replacing bloated ones and only with other old used caps.
Reply 4 of 9, by jwt27
... there was never any thermal paste at all! Con dos cojones 😵 . A pea of Artic Silver 5 and back to its position it went.
Ha! I recently discovered that on my MS-6119 board, too. The heatsink surface was also very rough so it was just there for show. Maybe the heatsink is not really necessary after all.
But I polished it a bit an put some toothpaste on anyway.
Reply 5 of 9, by TELVM
PeterLI wrote:
... Too bad you live in ES: I have a MOBO that needs to be diagnosed/fixed. 😵
You may contact Topcat, the master of Badcaps.net . He's headquartered at US-MO.
Skyscraper wrote:
I should order some new caps ... I have the bad habit of only replacing bloated ones and only with other old used caps.
Yep, any bloated cap means its apparently healthy neighbours must be regarded wit utmost suspicion. Also sometimes visually OK caps are totally FUBAR inside. By replacing only part of the lot we're just briefly delaying a potentially gory outcome.
The 17 fresh top-notch jap caps for this mobo cost me a bankrupting grand total of 8.33€ + VAT.
jwt27 wrote:
... put some toothpaste on anyway.
🤣 Fluoride toothpaste gives the best (if ephemeral) results 😁 .
Australian Vogoners may also try Vegemite (whatever that thing may be 🤣 ).
Let the air flow!
Reply 6 of 9, by bestemor
What is that stuff around the coils ?
Reply 7 of 9, by PeterLI
Thanks! Although his prices are fair the MOBO is not worth the $85 it would cost. I may have to learn to do it myself or just chuck it. Buying another refurbished one, should I need one, would be cheaper. I also have a HP Brio with a MOBO that has caps that leaked already (or so it appears) but the machine still works 100% strangely enough. 😕
Reply 8 of 9, by TELVM
Heat shrink tubing. When shrouding inductors, that get blazing hot while under operation. The shrinking is "self-generated" the first time we start the comp :
file.php?mode=view&id=243730
It prevents that torching warmth from being passed by contact to components in close proximity and sensitive to heat, like capacitors.
It also can mitigate potential "coil whining". PSU makers know this trick well.
@ PeterLI: I'd lend a hand but I'm at the other side of the pond 😀 .
Let the air flow!
Reply 9 of 9, by TELVM
(The long ago posted pics had vanished over the years, I've refreshed them for future reference).
Let the air flow!
