Reply 20 of 53, by Skyscraper
I managed to get the MSI slotket working with P3 Coppermine CPUs.
This slotket is much better than the no name FC-PGA slotket I have been using with the Aopen AX6BC so far.
The no name slotket made the motherboard think that all Coppermine CPUs use 1.5V and with no voltage setting in the bios setup anything over ~900 mhz was unstable.
The Aopen AX6BC also had stability issues with most video cards @133 mhz FSB even if a P3 800(133) Coppermine CPU was used (The board was configured to use the 2/3 AGP setting with jumpers).
With the MSI slotket configured to 1.75V all problems seem to be gone, at least with the P3 1000(133) I am using at the moment.
This made me order a "MASTER" version of the MSI slotket with the voltage clamp chip so I dont need to worry when the modified Tualatin arrive.
Now when the AX6BC is stable at the 133 mhz FSB setting I wish I had ordered the P3 1400S and not the Celeron 1400 though.
The Celeron will be good for the Abit BH6 😀 so it is not wasted.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
