Reply 20 of 27, by STX
leileilol wrote:
Large 32gb+ drives often had floppies with special partition tools to allow you to make large partitions for Win9x
Weren't there still problems though? I have a vague notion that an improper shutdown would cause ScanDisk to run; then, Windows 95's ScanDisk would corrupt the large partition.
Maybe I'm mischaracterizing https://support.microsoft.com/kb/243450.
Reply 21 of 27, by ReeseRiverson
vetz wrote:
It is not the drive that is the issue, it is the partition size. Just split the 80GB into partitions below 32GB and you'll be fine.
I tried that, but it still threw a fit. 🙁
Reply 22 of 27, by Mau1wurf1977
I installed Windows 98SE on 250GB and 320GB drives. But, like I always recommend, I create a single 30GB FAT32 Partition and I also use modern PCI SATA controller cards.
With these old machines there are so many things that could be wrong, so for me at least, SATA controllers is a tried and tested method which I stand by and recommend wholeheartedly 🤣
If that drive installs on a Pentium 3 system you can rule it out.
Also the more you build, you will develop a set of "known working" stuff. It will then become a lot easier to isolate the issue.
My YouTube channel
Reply 23 of 27, by ReeseRiverson
Well there will certainly be more projects, for sure! 😀
I don't doubt the SATA controllers one bit, I mean who knows? Maybe the one I have in particular is one Windows 95 doesn't like. I plan to buy a couple more controllers, since they are cheap, and give them a try.
Also funny you mention Pentium 3 system, I was thinking about going ahead and pop that controller and 80GB drive into my Pentium 3 to replace the 8GB drive Windows 98 is currently installed on. 🤣
Reply 25 of 27, by ReeseRiverson
STX wrote:
It would make sense to put the 80 GB drive in the Windows 98 system and the 8 GB drive in the Windows 95 system. It will Just Work™.
That or see how Windows 95 will behave with a 40GB IBM IDE Harddrive I have. 😀
Reply 26 of 27, by STX
Well, maybe if you can find one of those floppies that leileilol was talking about. I think I still have one for IBM Deskstar drives.
