First post, by obobskivich
- l33t
Okay - was tinkering with my Pentium 4 tonight, getting read to load an OS on it and move to re-casing, and figured I'd do some diagnostics on the hard-drives just to be safe (Good thing I did - caught one that's bad, and replaced it). Anyways - the primary drive, a Hitachi IC35L060AVV207-0 seems to have "locked" itself for no ostensible reason; it was running the IBM Fitness test, I restarted and was going to wipe the MBR to install my OS, and I get "cannot read/write, disk password set - security maximum!" (and here's the kicker - Fitness Test won't run if that was true, which means it magically (unless someone has a better explanation) did this by itself). The system never asks for a password during boot-up and the BIOS is fine to view the drive, change DMA settings, enable/disable SMART, but it annoys me that this drive is "locked" for no good reason! (There is no password set by the BIOS - it is unlocked). And yes this is a real question - I know, by all laws of science this is technically impossible; but remember we're dealing with a DeskStar after all.... 😵
How do I murder this setting with extreme prejudice? (I'm not paying for some "shareware try and buy" noise)
If there's no easy solution we'll move to murder the drive with extreme prejudice. 😈 (I have a very large selection of very large tools for this job...)
Blargh!
