First post, by SPBHM
- Oldbie
So I have this P2B 1.06 (I think, but I'm sure it's lower than 1.08 meaning it can't work with voltage lower than 1.8v, so officially no coppermine support, but bios with support for it), it's running a Pentium II 400 and a Voodoo 4500, I've been thinking for a while about getting a coppermine around 1GHz for it to be a little more balanced a run a few newer games (like 2000-2001 games), but unfortunately here in my country I can only find those basic slocket adapters with no voltage control at all, so I've been thinking about following this pin mod wire trick to force 1.80v on a 1.70v coppermine 900 or 750 http://www.overclockers.com/voltage-mod-for-p … the-wire-trick/ just connect VID1 to VSS, sounds easy but, the information there is not specific to my hardware or the socket to slot1 adapter, so my question is, would it work?
I mean the pin mod directly in the socket from the slot1 adapter would be detected fine by the MB as 1.80v?
anyone had any experience with something similar? I think it should work, but if not, knowing not to waste my time and money with it would be nice! thanks
