First post, by jwt27
- Oldbie
About that "goldmine" I was talking about in the other thread... Well, I was able to pick it up yesterday already. Not sure if you could call it a goldmine or not. It certainly is a lot of old junk. There was waaay too much stuff to take in one go so I just grabbed anything that looked pre-P4 or otherwise interesting, and not too broken. Most things were badly damaged, unfortunately.
He even had four 14" CRTs, but they turned out to be monochrome terminals (one with original keyboard) which I didn't see much use for. Are these worth getting?
Also found a board with AMD 8086 in a badly damaged case. Couldn't get it out of the case quickly so I'll go back soon to get it.
I promised to return any broken or non-interesting parts and pay him afterwards. Could you guys help me identify all this stuff and decide what to keep and what not? Also if you manage to spot anything damaged (other than bent pins) on these low-res pics please let me know!
RAM and CPUs. Left to right, top to bottom:
A bunch of SDRAM. I think I'll keep any 128MB+ and PC133 modules and return the rest.
Athlon64 X2 5000 (ADO5000IAA5DO) Tested: working
Athlon64 3200 (ADA3200DAA4BW)
Athlon64 3500 (ADA3500DAA4BW)
Pentium 4 3.2G/2M/800 LGA775 (SL7Z8)
Pentium 4 3.6G/1M/800 LGA775 (SL7J9)
Xeon 2.4G/8M/1088 LGA775 (SLACT)
Mobile Celeron 700 (SL4GX) Looked unusual at first but not worth keeping I think.
Pentium 133 (SU073) Tested: working
K6-2/300AFR
P3 Coppermine 800 (SL4CD)
Celeron 766 (SL4P6)
Celeron 1000 (SL5XQ)
P3 Coppermine 733 (SL4CG)
Athlon XP 1800 (AX1800DMT3C)
Athlon XP 2600 (AXDA2600KV4D)
Slot 1 P3 Coppermine 650 (SL3XK)
Slot 1 P3 Katmai 450 (SL3CC) Doesn't say if it's a P2 or P3 on the case, haven't seen that before. Tested: working
AOpen FC-PGA slocket with Coppermine 650 (SL3XV), 100MHz Tested: working
Pentium 2 300 (SL2YK)
Asus P4R800-V Deluxe mPGA478 with onboard RAID
Slot 1 board. LEGEND-QDI?
Test results: POSTs fine, battery seems dead. Has a pretty neat 256-colour BIOS logo.
Asus TUSL2-C rev 1.04
Asus CUV4X-E rev 1.05
2x Asus P3B-F rev 1.04
Test results: both power up and POST. Date and time are still stored so the batteries are good too, however one is an hour behind and the other almost a week.
Asus P2B rev 1.02
Test results: shows no signs of life so far...
Intel Professional Workstation board. Looks like the best 486 board ever, with EVERYTHING onboard. Even LAN and SCSI! Unfortunately it is BADLY damaged, beyond repair I think. Guess I'll have to return it...
AOpen AX6BC Slot 1
Test results: Started up at first with 66MHz and 2/3 AGP divider (set to AUTO). The i740 did not like that and showed horrible artifacts everywhere. Works fine after booting with a Rage card and selecting the right settings. Has a BIOS feature to "Save EEPROM defaults" which seems useful. Battery is dead.
Asus P55TP4N Socket 7 with MediaBus 2.0
Intel Advanced/EV "Endeavour", socket 7
Test results: POSTs fine, battery is dead. One cap is missing and another is very loose, have to replace these.
left: unknown
right: SuperMicro S7XBE, LGA775
HP server board?
ATi Rage 2C
2x ATi 3D Rage Pro Turbo AGP (love that name)
Asus i740 AGP
Cirrus Logic CL543XPCI
Test results: All cards are working fine.
Circuit board with VFDs
PCI IDE controller
PCI-X SCSI controller
PCI 3Com NIC
8-bit ISA NIC
PCI USB2 controller
ESS AudioDrive ES1869
ALS4000 PCI
Opti 924 with YMF262 and vertical wavetable header
Opti 924 with OPL3 clone (LS-212) and Opti 941 wavetable synth
