cdoublejj wrote:hey would that explain why the Darks are so dang pale? i had to ramp the darkness up all the way.
Exactly. Given enough time the picture will be almost white even with the user brightness control set to zero.
cdoublejj wrote:you mean like these? [...] if that that's cheap cheap cheap.
I think a USB one would work fine, but just in case I'd get one like this or this and use a real serial port on a Win9x PC. Windas is one of those headache inducing pieces of software. 😵
For the monitor end of the cable I use a floppy power connector chopped off an old PSU. Fits perfectly! The monitor supplies the +5V so you don't need an external supply for the TTL-232 converter.
cdoublejj wrote:I'm wondering based on other readings if Windas could help sort out the M993s?
Your M993 sounds like it has a bad capacitor on the horizontal output stage instead of a software problem.
PeterLI wrote:I would personally just get another CRT. They are free / cheap when you look around. Best Buy and Goodwill take CRTs for free for recycling. 😀
Sure, low quality 14~17" CRT monitors are plentiful and free/cheap if you look around, but getting anything larger or higher quality in decent shape for a decent price... not so easy.
