First post, by maximus
- Member
A follow-up to this thread, in which I describe a wavy distortion pattern affecting the VGA output of my Hercules GeForce2 Ultra. I eventually concluded that this was just some kind of design flaw. The GeForce2 Ultra was known to have this problem, and since it's not really that offensive, I decided to just move on and enjoy the otherwise awesome card.
Imagine my surprise, then, when I fired up a Matrox G400 MAX in the same rig and saw EXACTLY the same distortion pattern! Actually, the Matrox seems to have it even worse. Refer to the mock-up from the original thread. It's really, really bad. The GF2 Ultra was still usable, but the Matrox is so bad that it hurts my eyes after a while.
All of this from a card which was known for having the best 2D image quality of them all. What the bloody hell is going on here?
I've ruled out the following potential causes:
- power supply - swapped it out, nothing changed
- monitor - tried on an LCD at 60 Hz and a CRT at 85 Hz - does it on both
- hard drive - turned it off, same problem
- sound card - took it out, same problem
- CPU and case fans - unplugged them, same problem
- electric grid / environmental factors - tried it in two different houses in two different cities
The only thing I've done so far that's made any kind of difference is underclocking the CPU, a Pentium III 1400S. (Actually, I had to drop the FSB and memory clock to do it, so I underclocked a number of things). This didn't get rid of the lines, though - it only changed the pattern.
This last bit leads me to the conclusion that the lines are caused by radio frequency interference generated by the CPU. However, if that's the case, why does it happen with some cards and not others? So far, this problem affects the GeForce2 Ultra and the G400 MAX, but not the 3D Prophet 4500 or the Rage Fury MAXX. Actually, it's even stranger than that: the G400's secondary VGA output seems to be unaffected. (This wasn't the case with the GF2, though.)
Gahhh, I'm getting stumped here... aside from wrapping my whole setup in tinfoil, I don't know what else to try. I'm almost tempted to buy another G400 to see if it has the same problem. What happened to that legendary Matrox image quality?
Truly, this problem is utterly bizarre.
