First post, by robbo007
Hi all,
I'm going to buy an origina IBM 5150 (model PC 130A) PC and want to use it in Europe. It got a sticker on the PSU that says input voltage selector 110V/220V. Does this mean it can be used on in European power?
Do i just have to flip the switch on the PSU?
Thanks,
Rob
Reply 2 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If there's a selector switch you need to move it to the 220V position of course. But with these old buckets it can happen that it has a jumper wire inside the PSU which has to be moved.
1+1=10
