First post, by soviet conscript
- Oldbie
I was thinking about this and I know if can be a very general question that depends on other factors but as a broad question what is generally considered better for a PC gaming environment, more RAM or faster RAM?
I have 2 examples myself. first is a modern board I have. It supports either 4GB of DDR2 or 2GB of DDR3. from the couple people I talked to In the Windows XP gaming environment I'm going to set up most people tell me to go with 4GB (or 3.5 for XP) of DDR2
now I also had two power macs, a G3 upgraded 7600 and a G3 machine. they were both fairly similar but the 7600 only supported DRAM to a limit of 1GB while the G3 could handle SDRAM to a limit of 768MB. what would generally perform better in a gaming environment if were only taking RAM into consideration?
