Reply 20 of 22, by j^aws
^^ Check if your BIOS has options for '8bit/ 16bit IO Recovery Time' or something similar, and add more latency to see if that fixes it. Also try swapping 8bit/ 16bit around so that one has more latency than the other, and vice-versa. Just a suggestion if no one has tried this yet...
Reply 21 of 22, by LunarG
I didn't replace my motherboard, I changed CPU's, but perhaps more importantly, removed my network adapter. I have not put the network adapter back in the system, because I don't really need Ethernet connectivity for a system that old, so I cannot say for sure that there wasn't some conflict between the GUS and the network adapter. Although, for a while they coexisted harmoniously and the problem only "suddenly appeared".
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, Waveforce 192XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, ELSA Winner 1000PRO, GUS 1MB, SB16.
Reply 22 of 22, by mOBSCENE
Thanks for your suggestion. My BIOS only has an option for "IO Recovery Time". I've changed this from the default 0 to 1,2 and 3, but it did not have any effect on the distorted sound unfortunately.
Sorry, I misread that (changing CPU instead of mobo). Thanks for your reply.
I've removed the network adapter, but it sadly has no effect on the GUS. Also, I find it very convenient to have a network adapter available at my DOS machine, for imaging to a Samba share or copying new games over. So I'm kind of glad this is not causing the problem 😀
I will see if removing any other add-on card has an effect on the GUS. I really want to solve this!
