First post, by dacow
- Member
So I bought a 386DX40 motherboard a while a go to replace an existing motherboard which was in a case I bought off badmojo (http://goo.gl/KDeqPA). I bought it probably over 12 months ago but haven't really had any time to fire it up. Long story short, I powered it up this morning and well it powered on for around 10-15 seconds, no display and then the whole unit just powered itself off.
As part of my troubleshooting steps, I removed all the cards except the video card and attempted to power it back on. I noticed the system had power for a split second and then nothing. Scared I had blown the PSU, I put all the old parts back in the case and voila off she went again *phew*.
Can a bad motherboard blow up a power supply? Also is there anything/any point in attempting to troubleshoot this bad motherboard or should I just bin it? I'm worried about blowing the AT psu for obvious reasons 😀 Reasons for swapping the motherboard out was the fact it had a header for an external battery connector and some cache chips 😀 No corrosion that I can see on the board.
