Reply 60 of 71, by Jorpho
- l33t++
wrote:I distinctly remember it saying driver provided by oak technology
That would be your CD-ROM driver, but there is no such driver being loaded by the autoexec.bat and config.sys you have provided above. In fact, you are loading very little in the configuration you have provided above and there should not be much text at all.
Is there a way to slow down the boot screen so I can read everything?
There are numerous tricks depending on exactly what you need; sometimes it's easiest just to hit the PAUSE/BREAK key on your keyboard, though on a fast computer the timing can be tricky. In the AUTOEXEC.BAT you can insert the word PAUSE on its own line after each existing line; with config.sys it's a little more tricky.
