First post, by Artex
I saw one post about a 1 x 6 pin (all pins in one row) header & PS/2 bracket that indicated the connector was non-standard. I have an Asus PVI-486SP3 board with a 2 x 4 PS/2 mouse header on the motherboard but I have no bracket. Wondering if this will work..
http://www.startech.com/Cables/Serial-Paralle … Bracket~PLATE6F
Has anyone purchased one of these before, for use with an older motherboard? I know what the pinout should be for both the motherboard and PS/2 connector, but just curious if these 'just work' out of the box without any modification.
Reply 2 of 42, by Artex
RacoonRider wrote:
Modification is so simple you need not bother.
Is there a guide out there? How do you crack open the black connector to move the wires around?
Reply 3 of 42, by 5u3
No need to crack it open. The wire terminals are held in place with the help of little plastic "tongues" which are part of the connector and can be slightly bent back to release the wire. It is really very straightforward once you look at the connector.
Reply 4 of 42, by Artex
Cool - I'll grab that one then and see how it goes.
Reply 6 of 42, by vetz
bestemor wrote:
Too bad this one seems like Germany only (and no paypal?)
http://www.ebay.de/itm/221461722240
(for ASUS mobo P55TP4N, but will most likely work on a Asus 486 as well?)
They work on all ASUS motherboards (and Aopen) I've tried.
Reply 7 of 42, by Artex
Are you referring to the one I posted or the one pictured above @ DE eBay?
Reply 8 of 42, by vetz
The one pictured above 😀
Yours should work too with changing the connector as described 😀
Reply 10 of 42, by Artex
Ok, so I've picked up two of these PS/2 brackets. I have a multimeter (documentation attached) - can anyone instruct on how to do this?
    gdt-311.pdf
    1.04 MiB
    294 downloads
    Gardner Bender Digital Multimeter GDT-311
Reply 11 of 42, by Jorpho
There's not much to say. You have the 2x4 connector, right? All you have to do is remove the pins from the old connector and put them into the new connector. If you know the pinout for the old connector you don't even need the multimeter.
As for removing the pins, it's tough to describe. You'll need to gently poke at the sides of the connector with a needle or other sharp object. As always, you should never apply too much force.
Reply 12 of 42, by schlang
this is from my 486 PVI SP3. hope it helps =)
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 13 of 42, by Artex
The bracket I picked up has red, green, blue and black wires.
Reply 14 of 42, by Artex
So.. please excuse my novice MS Paint skills. But.. I think I may be ok here. I dug up the pinout for a standard female PS/2 end and the 8-pin header arrangement for Asus Motherboards using this FAQ, and then used my multimeter to test continuity (actually, resistance in Ohms since my multimeter doesn't seem to have a continuity test mode) & color-coordinate the pins/wires of the female end to the metal pins of the connector.
Red->Red (Pin 1 - Data)
Blue->Blue (Pin 3 - Ground)
Black->Black (Pin 4 - +5V)
Green->Green (Pin 5 - Clock)
Does this look right?
Reply 15 of 42, by vetz
Artex, isnt this another JRTFM case?
http://www.datasheets.pl/motherboards/MOTHERB … ARD_P55TP4N.pdf
Page 19 (#5.2). It's in all relevant ASUS manuals AFAIK (and it's the same pins)
EDIT: Just saw you linked the FAQ, which has the same info.
Reply 16 of 42, by schlang
nope, the PVI SP3 manual does not mention the PIN layout.
plug it in and tell us if it works 😁
Reply 17 of 42, by Artex
So does this look right?
Reply 18 of 42, by vetz
Yes 😀
Reply 19 of 42, by Artex
vetz wrote:
Yes 😀
Sweet! 😀 Wanted to test since others have complained that they've had to re-wire their connectors.
