The Yamaha FB-01/IBM Music Feature Card support thread!!
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby carlostex » 2014-6-15 @ 13:11
Hello there!
I'm pretty sure other threads about these specific sound devices already exist, but i wanna focus on these sound devices as far as knowing which games supported them and to document how we can get them to work.
I'm not gonna give the details and backstory into these devices, it's been documented all aound.
Anyway, the point is game support for these devices, specially for the FB-01 since it is so much easier and certainly cheaper to acquire than an IMFC.
The following pic, courtesy of Cloudschatze are very good to determine Sierra games support for sound devices, including the FB-01 and the IMFC:
Now for those owning a FB-01 (like me) there is still need for MPU-401. Using SoftMPU is therefore essential for those who don't own a real MPU-401 hardware interface. There was a problem with some Sierra games giving a dump/error message on the FB-01, so better support through SoftMPU and sierra FB-01 driver investigation has followed and came to culmination here:
viewtopic.php?f=57&t=36023&start=220
Ripsaw8080 managed to do his magic on the Sierra drivers and figured out the problem on the FB01 Sierra drivers, that were causing dump errors on the FB-01 sound module.
So for starters i would like to use this thread to document game testing, not only for Sierra games but others as well that might support the FB-01 and IMFC.
User avatar
carlostex
Re: The Yamaha FB-01/IBM Music Feature Card support thread!!
Postby carlostex » 2014-6-15 @ 13:16
I tested the following games so far with ripsaw8080 modified Sierra Driver:
Space Quest 3 -- OK!
Leisure Suit Larry 2 -- Wrong and garbled notes!
Leisure Suit Larry 3 -- OK!
King's Quest 4 -- OK!
Police Quest 2 -- OK!
Silpheed -- OK!
Keep in mind that some game versions might not work correctly. I haven't found a Leisure Suit Larry 2 version (including my owned original copy) that works correctly with the FB-01.
User avatar
carlostex
Postby Great Hierophant » 2014-6-15 @ 18:38
The following games worked with ripsaw8080's driver with a real Yamaha FB-01 and Roland MPU-401 + MIF-IPC-A :
Codename : ICEMAN
Colonel's Bequest
Conquests of Camelot*
Hero's Quest/Quest for Glory I
Hoyle's Book of Games : Volume 1
King's Quest I
King's Quest IV
Mixed-Up Mother Goose*
Police Quest II
Silpheed
Sorcerian
Space Quest III
* - needs patch.002
Games that will not work with either Sierra or ripsaw8080's FB01.DRV are :
King's Quest V
Quest for Glory II
Thexder 2 : Fire Hawk
King's Quest IV (version 1.006.111 or 1.000.111)
Leisure Suit Larry 2 (v1.000.011)
1988 Christmas Card Demo
User avatar
Great Hierophant
Postby MaxWar » 2014-6-15 @ 18:55
Hehe, funny, literally 2 days ago I was reading the equivalent thread on Questudios forum and marveling at the prospect of taking my FB-01 out for a stroll.
But at least here I can post :p
Here are other relevant threads:
http://www.vogons.org/viewtopic.php?t=9555
http://queststudios.com/smf/index.php?topic=3384.0
http://www.vintage-computer.com/vcforum/showthread.php?26369-IBM-Music-feature-card
http://www.vintage-computer.com/vcforum/showthread.php?28030-PROGRAMMING-the-IBM-Music-Feature
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
User avatar
MaxWar
Postby carlostex » 2014-6-15 @ 19:49
Great Hierophant wrote:Games that will not work with either Sierra or ripsaw8080's FB01.DRV are :
Yeah that's the exact Leisure Suit Larry 2 version i have...
Are there any non Sierra games that might have support for the FB-01?
User avatar
carlostex
Postby PeterLI » 2014-6-15 @ 19:56
Cool. I might be tempted to get a FB-01 again now. :)
PeterLI
Postby bristlehog » 2014-6-15 @ 21:13
By the way, is there a FB-01/IMFC programming guide anywhere?
User avatar
bristlehog
Postby kreats » 2015-8-18 @ 15:30
QfG VGA doesn't seem to work for me with ripsaw8080's driver - should it?
kreats
Postby Cloudschatze » 2015-8-18 @ 17:02
kreats wrote:QfG VGA doesn't seem to work for me with ripsaw8080's driver - should it?
No, that driver isn't compatible with the later, non-SCI0 releases. Also, unless the music resources were lifted straight from the EGA version for the VGA release, the necessary FB-01/IMFC MIDI track data would be missing besides.
User avatar
Cloudschatze
Postby kreats » 2015-8-19 @ 08:12
I suspected as much - good to know for sure though!
Thanks again cloud.
kreats
Postby Stiletto » 2015-8-19 @ 16:47
bristlehog wrote:By the way, is there a FB-01/IMFC programming guide anywhere?
Better late than never: IBM PC Music Feature Technical Reference: ftp://ftp.oldskool.org/pub/misc/Hardwar ... erence.pdf
FB-01, I can offer the manual and service manual. Dunno about a programming guide:
http://soundprogramming.net/manuals/Yam ... Manual.pdf
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby pleonard » 2016-3-20 @ 00:35
Not sure what made me try, but the IMFC fits (and works) inside a PS/2 Model 25:
And yes, the machine can close too... The top slot is, unbelievably enough, a full 13" long. As you rotate the bottom closed, the end of the IMFC goes all the way into the monitor's lower lip, which extends an inch or two from the front of the Model 25. The lower slot is shorter, as it meets the floppy bezel underneath the monitor lip.
You often see the Model 30 listed as the only ISA-based PS/2 model this card will work with, but we can add another to the list.
pleonard
Postby Yart » 2018-4-18 @ 20:49
Sorry for the necro-post, but I'm getting the "dump/error !!!" error with my FB-01 in DOSBox 0.74 trying to run Silpheed using the fixed FB01.DRV.
Has anyone else encountered this issue with DOSBox too? I can't seem to get it to work.
I'm running the FB-01 through a Roland UM-3EX to my PC, a Midi to USB adapter of sorts. I've tried DOSBox's MIDI setting with both Intelligent and Uart modes.
Yart
Return to Sound
Who is online
Users browsing this forum: pdw and 2 guests
