Ps/2 on AT-Systems
Reply 20 of 33, by feipoa
I have only seen it whereby you can use DB9 RS-232 and RS-485 serial devices on a USB port, not the other way around. If you have a link to someone who has made a converter that lets you use USB mice on a computer's RS-232 serial port, I would be interested.
Reply 21 of 33, by brostenen
Only posted a link to that db9-usb-m converter-kit, early in this thead. 😀
Took me a week to find. Not good at gogling by the way.
Here is a link for the youtube video I found: https://www.youtube.com/watch?v=PosPLX8Qw08
Shure we need drivers now, yet, wich and how?
Reply 22 of 33, by brostenen
I think this is the best shot at getting stuff working in dos, at the moment.
Unless we do some programming on one of those arduino serial/usb converter modules.
And I am not good at programming at all. 🙁
Reply 23 of 33, by Maeslin
As mentioned earlier, that usb-rs232 adapter won't work. It's a USB DEVICE, you'd need a USB HOST. It's not meant to go on the motherboard side but on the external peripheral (modem, graphic tablet, printer, etc.) side and hook up to a USB-equipped computer.
Reply 24 of 33, by brostenen
Damn.... That was not what they made clear in the video.
Looking at the manual, it is stated somewere deep (and written were I did not notice it), that host is needed.
I give in. Damn.
Reply 25 of 33, by brostenen
I might just buy this, then....
http://www.vetra.com/327text.html
Or
http://www.jasystems.co.uk/ps2-serial/pc1702- … 4306-643871.php
Reply 26 of 33, by archsan
^ at those prices, might as well look out for a bunch of DIN keyboards and serial mice sold cheap as "lot" deals etc.
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 27 of 33, by feipoa
If you don't mind your mouse skipping around a bit with some lag, go ahead with the vetra systems converter. Also keep in mind that they have 3 such converters. All convert PS/2 signals to RS-232 signals and each unit requires a very specific mouse driver that you will need to hunt down. The driver is not supplied with the unit.
Reply 28 of 33, by brostenen
If I manage to track down a driver that works, would they still do the trick using dos only?
Reply 30 of 33, by PeterLI
Serial mice are extremely common and cheap so this whole exercise appears very excessive (IMO). 😀 You can go USB to PS/2 to DIN.
http://www.l-com.com/usb-tripplite-usb-to-ps-2-adapter
http://www.l-com.com/firewire-din-scsi-sata-k … -din-6f-din-50m
Reply 31 of 33, by schlang
I hate "oldskool" serial mice and I love using state of the art wireless USB mice which support PS/2 protocol.
How is this possible? Using CTMouse and the serial-ps2 converter from ish-gmbh (item no. 00004942
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 32 of 33, by dirkmirk
I have the Raritan converter and I have no issues with it personally, ive used it in resolutions up to 1024x768 no problem, a few years ago 2 of them on American ebay for about $30 I bought one because I wasn't sure if it was going to work as I wanted it to, someone else bought the other one should have bought both in hindsight.
Reply 33 of 33, by feipoa
Between the Raritan, Vetra and KVM-based converters, I personally found the Raritan to perform the worst. I wonder if the types of PS/2 mice tested has something to do with it. My test mouse was a Logitech MouseMan (trackball). My screen resolution was 1280x1024 in Windows NT 4.0. I do recall reducing the resolution, but still found some lag and jumpiness, which decreased with decreasing resolution. I am accustomed to using a PS/2 mouse over a serial mouse, so my judgement might be somewhat spoiled in this regard.
dirkmirk, would you be willing to test your Raritan on a system which has both a PS/2 mouse input and a serial input using a screen resolution of 1280x1024? Test the mouse on the PS/2 port then compare it directly on the serial port. For me, even at 1024x768, the mouse had so much lag I found it difficult to navigate through the Start Menu programs. I do recall adjusting the baud rate and other various settings but to no avail.
