Bad news...I cant get it to post...actually can't get anything on the screen or even a single beep.
Though the GPU does warm up a little if left on for 10mins or so...but that's it.
I've just had the time to put this pc together.
However it simply doesn't work.
I'm only connecting the basics to test:
500w PSU
3dfx voodoo 3-3000 (agp), gf2-200 (agp), s3 trio (pci)
64/128/256 (3 of each tested one module at a time)
AMD k6-2-533
AMD k6-2-533+
Simple CPU fan
CMOS was reset using jumper
When switched on the cpu fan spins up, psu fan spins up, power led comes on.
That's it... no sound via the pc speaker.
As per the above specs i tried multiple video cards, ram sticks and 2 cpu (which have been confirmed to work).
I used the official 5.0x jumper settings, even tried to set to 400mhz and lower bus/ram freq.
Since it doesn't even give a simple beep I can only assume that the board is dead.
The packing was horrible, no protection for the board from static what so ever.
A box with foam on the ends only, so physically it's fine but i'm pretty sure static from going over seas would have killed it.
