Reply 20140 of 27575, by bjwil1991
Ouch. Having faulty RAM isn't the best thing in the world. Learnt the hard way with my SIMM-30 RAM on my 3/486WB board that had faults (either didn't POST or would boot, but everything crashed). Good thing I had spare RAM lying around, but I know how it feels to have shotty RAM. If there was a way to fix RAM, such as replacing capacitors or RAM chips, which might not be possible.
Reply 20141 of 27575, by mastergamma12
dormcat wrote on 2021-10-15, 03:16:
Just tested my all eight SDR SDRAM with MemTest86 for the first time yesterday and found three of them were quite faulty. 😿 Will test EDO RAM x5 and DDR SDRAM x13 later today.
F
Good luck with the other sticks
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 20142 of 27575, by dormcat
bjwil1991 wrote on 2021-10-15, 03:25:
Similar situation here: the two PC133 256 MB sticks could boot into "Safe mode command prompt only" of Win98SE, but entering GUI would crash. OTOH the PC100 64 MB stick tested on Gigabyte GA-6VXC7-4X-P with AMI BIOS would give me a strange 6-beep Gate A20 error code (yet the keyboard is perfectly fine, of course); wouldn't POST anyway.
Reply 20143 of 27575, by bjwil1991
Yeah, I had a similar issue in the past with my Socket 7 (non-AGP) one time and I took the faulty RAM out and put in a spare I had.
Thankfully, after replacing it, the system ran fine.
My main Windows 10 desktop was the opposite: random BSoD/STOP codes and the 4GB stick I had installed was defective.
Reply 20144 of 27575, by Brawndo
I stripped and thoroughly cleaned up my most recently acquired Core2Duo tower and power supply. Left all the parts out so I can clean them all with some electronics cleaner tomorrow before putting it back together, apply new thermal paste to the CPU heatsink, all that jazz. I'll post pictures with everything cleaned up.
Reply 20145 of 27575, by appiah4
In other news I finished 5 PS2-Serial adapters by @scorp
I'll program the SBCs over the weekend.
Reply 20146 of 27575, by sirotkaslo
I had an interesting journey... not. Win95 wouldn't boot anymore. Tried a clean install, sincer the error was some vxd error. Nothing. Replaced HDD and another clean install - nothing. Ran a memory test everything ok and was detected as 128 MB so i wasn't even looking at it. Well it turned out that one of the sticks just needed a change of slot., joys of retro pcs I guess.
Reply 20147 of 27575, by mastergamma12
sirotkaslo wrote on 2021-10-15, 06:09:
I've ran into stuff like that before. Was a PITA.
Reply 20148 of 27575, by ODwilly
I inherited a Toshiba Tecra 8100. Apparently a decent sound chip, a S3 Virge, and a 600mhz or so p3. It turns on, the screen back light turns on, but no nothing.
Reply 20149 of 27575, by RandomStranger
RandomStranger wrote on 2021-10-13, 18:58:
Today I was trying to go on a test run with one of my Trio3D/2X 8MB and I found it unusually troublesome. I've been planning on […]
I've been planning on experiencing the true potential of this beast, but games either won't launch or only run in software mode.
So far the only games I had a modest amount of luck with are:
GLQuake with 8.8fps on Demo1 in 640x480@16 which is slower than expected
Tomb Raider 2 with 12fps
International Rally Championship with 10fps
Thief: The Dark Project with 8fps (though none of the textures loaded, some grey objects in a white void)
Gorky 17 with 32fps, the game claims to be running with 3d accelerated, but it's oddly fast
Need for Speed 4 starts in Direct3D the menus are all glitchy, which is not unexpected, and freezes the system on the loading screen
Yesterday I've continued torturing the Trio3D.
It looks like it has "better" support for later 3D titles. Prince of Persia 3D is really a unique experience with this card.
IMG-20211014-193210-result.jpg IMG-20211014-193631-result.jpg IMG-20211014-193837-result.jpg
Baldur's Gate 2 is actually displays correctly and I need both my hand to count the frame rate. Even on heavier areas it puts out 6fps.
Reply 20150 of 27575, by ODwilly
ODwilly wrote on 2021-10-15, 06:35:
Weird question, but are mobile p2 and 3's interchangeable between laptops? My Dell with a Rage 128 and 300mhz p2 could utilize a better CPU.
Reply 20151 of 27575, by xcomcmdr
RandomStranger wrote on 2021-10-15, 07:09:
Yesterday I've continued torturing the Trio3D. It looks like it has "better" support for later 3D titles. Prince of Persia 3D is […]
Oh my God ! 🤣
Reply 20152 of 27575, by Sombrero
Immediate flashpacks of early days of Radeon 8500. Though I did get slightly better fps with it 🤣
Reply 20154 of 27575, by ST251
oh look, a 486 with an MFM hard drive in it running Windows 95
And if you're wondering, yes, the case's HDD LED is connected to the MFM controller in a display of redundancy.
1.46 MiB
Reply 20155 of 27575, by thp
I bought a Voodoo Graphics card again recently for development/testing purposes (finally figured out that Glide2x needs to have its vertex positions snapped to multiples of 0.0625 units, so it doesn't lock up -- obviously didn't happen with any Glide Wrappers or Emulation), but since it didn't come with the passthrough cable (it has the non-standard Mini-DIN-9 port for VGA In), I used the pinout document available online and used jumper cables (the ones that are used e.g. to hook up Arduino pins to a breadboard) to make a ghetto pass-through "cable", as unplugging and re-plugging the monitor became tedious quite quickly. It works for now (VGA signal passed through nicely from the primary video card), and will eventually be replaced once a proper Mini-DIN-9 plug arrives.
    98.68 KiB
    Ghetto VGA Passthrough
Reply 20156 of 27575, by BitWrangler
ST251 wrote on 2021-10-15, 16:02:
Heh, I seem to remember doing that in the mid-late 90s, think it was very much "for the lulz" though as a) it only just fit on there and b) it was as bad as 9x can be on limited hardware, only somehow more so. It was only the floppy version too, lightest version around, mind you I think I only had 5MB and a dx33 in the box along with it. (5Mb because it's marginally better than 4MB and the 256k SIMMs keep dust out of the empty 30 pin sockets. 🤣 )
Reply 20157 of 27575, by MMaximus
That's cool - what MFM drive do you have in there?
Now you just need a beige drive bay faceplate 😄
Hard Disk Sounds
