Reply 20580 of 29860, by PcBytes
- l33t
Kahenraz wrote on 2021-12-25, 17:15:I happened to really like this era of laptops. A low TDP Core 2 Duo with dedicated GeForce 8 series is a powerful combination. I had a great HP laptop with this combination around this time.
I asked a professional repair service if it was worthwhile getting one of these GPUs reballed and professionally reconditioned but was told that the business had a very low success rate and that there was some other underlying cause for the failure. This is everything I know.
The reason of failure was simple - the GPU substrate between the die and chip itself was crappy.
There were two batches of chips because of that:
- the first run of the chips were the bad batch - the easiest way of finding those is looking at the chip part number - bad chips are numbered even (eg. G86-770-A2 for 8600M GS, G86-730-A2 for the 8400M GS)
- the second run of the chips were the good ones - these not only were numbered odd, but can also be identified by a milky white underfill glue around them, the same one present on most mobile Geforce 9 series chips. (eg. G86-771-A2 for 8600M GS, G86-635-A2 for 8400M G and G86-731-A2 for 8400M GS. Of worthy note is that the G86-635-A2 was also rebranded as 9300M G, at least for Acer - I do not know of any other manufacturer that uses G86-635-A2 as 9300M G, rather switching to the G98-630-U2 which is the 9300M GS in most cases)
