Reply 22460 of 27549, by Radical Vision
- Oldbie
Meatball wrote on 2022-08-18, 13:15:Every brand (probably) randomly chooses to dump on a random customer but gives someone else trouble-free operation over their lifetime.
I've never had any issues with Asus. My first board was an Asus P2B and I just bought a P2B-F about a week or so ago. In between '98 and now, I've had many Asus cards, boards, and etc. I've never had a single issue - not even one; even the one's with Via chipsets, though quirky, ultimately work fine.
As for "Razer," I've had plenty of problems with. Razer has been the worst. Failed mice, failed laptops (also with ridiculously loud fans), failed keyboards, and bloated software. The price has not justified the quality. It could be when I bought a bunch of their stuff around 2019, I got a bad batch, but it's soured me enough to where I won't be buying any of their crap again.
Well maybe u are lucky then... My first ASUS P3B-F was half working, and after some posts did die 🤣... The current P3B-F i own is working fine, but i will just trade that crap for GIGAbyte BX2000+ that is also higher tier class mobo then the P3B-F when it comes to looks, features ect... My ASUS K7M is also working fine, an NF2 Deluxe, and dual socket 462 ASUS, and on ASUS P2B that also works fine. Still i saw many dead ASUS mobos, more then MSI and GIGAbyte, so i just avoid the brand, dont like it much..
Cant agree more with razer, is prob one of the worst brands out there, many did complain about the same shit, broken keyboard switches, dead mouse wheel ect, ect... But i see no point to buy Razer when there is Logitech 🤣... As for keyboards i use the ultimate classics like IBM Model M, Cherry G80-1000, and others they never fail, and are build to last for many and many years....
effy wrote on 2022-08-18, 13:50:From working in a shop back in the mid 90's through early 2000's, I actually agree with Asus, at that time, being very poor qual […]
From working in a shop back in the mid 90's through early 2000's, I actually agree with Asus, at that time, being very poor quality. We constantly saw issues with their motherboards. Whether it was instability or straight up dying. We never really carried them anyway but had bought some slot 1 boards due to customer demand. Most of that lot ended up being sent back to the supplier after coming back a few months later dead. A handful lived, or at least weren't returned to us. The rest of the Asus issues we saw come in from customer built systems. Same thing, instability, dead for no reason, etc.
We actually carried mostly DFI boards for a long time as our standard. Very stable, well priced. Very low return rates. The KT133A and Slot 1 boards were especially good.
We also carried a ton of PC Chips and ECS products. (all of our low end PC's were built with them). The early days of all-in-one motherboards with VGA/Sound/Lan onboard. Being an enthusiast I hated the onboard trend at the time. I'll be honest though, they worked fine if you used a decent PSU. Cheap garbage PSU and these were a nightmare. We had surprisingly good return rates with those boards.
Speaking of brand names that sucked back in the day, Crucial memory was constantly a problem. Customers bought it all the time as they were a big deal in the direct purchase world. Stability issues would be fixed instantly with a memory swap out (we typically carried generic brand Samsung chip memory in bulk, or hell even Nanya and the like). I love their stuff now but back then they were definitely problematic.
Oyyy liked ur commet pure gold... I really like when ppl talk for back in the day is always interesting to me to read whatever for when in the time of 486 or slot 1, they was cutting edge HW...
Well the components quality of ASUS boards specially from slot 1 and above are very good, i mean they did mostly use Nichicon or Rubycon as caps on their boards, and they are expencive, some times they did use garbage Nippon KZG caps that are sure to fail, and mosfets seems also high quality.. The problem i think is in the build quality of how the board is engineered, and there is something very wrong, or is on purpose in order boards to die after they warranty is over or even before that in order to sell more motherboards... As i see pattern that mostly ASUS boards will die for no reason, and then many of them will just refuse to even spin fans, that is BS AF... Menawhile many others brands may die like MSI, GIGAbyte ect, but they at least spin fans, and the dead ones i am sure if i did take the care and time, there was some dry out caps, or dead mosfet, or something, so they cant post. Meanwhile ASUS is totally dead no fan spins, not even a small sign of life 🤣 wtf.... And yes as you mentioned some underDOG shit brands like PCchips, ECS, ASSrock, QDI and many others i rarely see them dead, i am not sure what the deal is with these doggo brands really, but they just dont die easy... I think about all ECS boards i had was all alive, that is why i use them as test subjects, and test new HW on ECS boards, and they "just work" 🤣... I heard from 1-2 enthusiasts that Micron memory is shitty, but i have x3 256MB SDram made in USA Micron memory and they work fine on Slot 1... Normally OEM memory is fine and works on most things.. I think HyniX, Infeneon and Samsung chips are problem free for the most part...
ynopot wrote on 2022-08-18, 13:57:Radical Vision wrote on 2022-08-18, 08:52:garbaged refuse garbage fucking garbage shitty garbage garbage garbage fucking worst garbage shit garbage garbage shit […]
garbaged
refuse
garbage
fucking
garbage
shitty
garbage
garbage
garbage
fucking
worst
garbage
shit
garbage
garbage
shitAlmost every post you make is like that. I even noticed something similar about the builds of other forum members. Shit, shit, shit, shit on shit...
You look aggressive. Bruce, maybe the problem is not in your environment, but in you...
Well i have to hand it to you, u got me, u broke the code i install AMD PGA CPUs on Intel LGA sockets (and the reverse ofc), AMD Slot A on Intel Slot 1, and i like to install memory sticks onto the PCI slots, and video/ audio cards on the DIMM slots, cant help myself. I also like to use mayonnaise/ tooth paste for the CPU/GPU since i am sure it does make the CPU/GPU faster u can bet.
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
