Reply 23240 of 23628, by MarkP
DundyTheCroc wrote on 2022-11-25, 08:46:There are many types of WD-40 sprays, for contacts, slots and other electrical equipment use that:
^^^ What he posted.
^^^ What he posted.
Shreddoc wrote on 2022-11-25, 10:28:^^But only if you want to clean moving contacts. Not as a general dousing / brushing of cards.
Wrong!
MarkP wrote on 2022-11-25, 10:32:Shreddoc wrote on 2022-11-25, 10:28:^^But only if you want to clean moving contacts. Not as a general dousing / brushing of cards.
Wrong!
Reasoning?
Using WD-40 to clean elecronics is like showering with DDT..
appiah4 wrote on 2022-11-25, 10:45:Using WD-40 to clean elecronics is like showering with DDT..
Rubbish. WD-40 Contact Cleaner is perfectly fine and readily available at a lot of retail outlets.
Detergent, water and convection are even finer, and are available at your home.
Save the contact cleaner for cleaning contacts imo.
Shreddoc wrote on 2022-11-25, 11:28:Detergent, water and convection are even finer, and are available at your home.
Tap water is usually contaminated with impurities. The people in Flint will confirm that.
Demineralised water is far far better.
appiah4 wrote on 2022-11-25, 09:03:Wrong: […]
chrismeyer6 wrote on 2022-11-24, 12:06:One of the uses for WD-40 is to spray into your distributor cap if there was moisture in there and your car wouldn't start. There's quite a bit of arcing in a distributor and people's cars didn't go up in flames. Wd-40 is only flammable while it's wet once the solvents in it evaporate it's fine. Don't forget the pvc insulation on your PSU cables are flammable as well. Isopropyl alcohol as well as most contact cleaners are highly flammable.
(Edit: spelling mistake)
Wrong:
Is WD-40 Flammable After Drying?
The main constituent of WD-40 is petrochemical distillates, so it is no doubt that the oil is flammable. However, when dry, it burns slowly without any sound, so it can be called more combustible than flammable. When heated, it goes under oxidation, releasing heat energy and making the oil more likely to combust.
let me guess, it needs an ATEX rating / DSEAR study 🤣
just use clutch cleaner, dry it out and if you live in areas where rust is an issue, like near the sea, apply some WD-40. Source: brian from techyescity
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Today I carried out a full Re-Cap of my Iwill SS7 Motherboard. Some of the caps were bulging and even though the board works, I want this board to be in its best condition.
Recapped with Panasonic caps. De-Soldering Gun Makes easy work of removing them! Thankfully the board worked after the operations!
Before
After
Final of recoloring)))
Need help? Begin with photo and model of your hardware 😉
gmaverick2k wrote on 2022-11-25, 16:34:appiah4 wrote on 2022-11-25, 09:03:Wrong: […]
Wrong:
The main constituent of WD-40 is petrochemical distillates, so it is no doubt that the oil is flammable. However, when dry, it burns slowly without any sound, so it can be called more combustible than flammable. When heated, it goes under oxidation, releasing heat energy and making the oil more likely to combust.let me guess, it needs an ATEX rating / DSEAR study 🤣
He is referring to the original waxed based WD-40 product, designed to prevent corrosion of rockets on rocket launch pads, not the WD-40 branded contact cleaner.
NEXT!
Babasha wrote on 2022-11-25, 18:03:Final of recoloring)))
WOW that's a beautiful color scheme. The muted blues/greys gives it a high-end workstation vibe in my opinion.
There's all this talk of WD-40 for cleaning electronics here... how about Deoxit? Some retro YouTubers seem to swear by it. "Deoxit that socket!" - Adrian's Digital Basement
I've been experimenting with DeoxIT for a while now, and I can recommend the smaller vials with a brush. The spray cans are really gross, it gets everywhere, and has some kind of oil or film to it that never dries. So you end up getting all of that overspray on your hands by touching the hardware afterwards forever, unless you clean it off in the sink. At which point you've removed all of the DeoxIT...
Bancho wrote on 2022-11-25, 17:45:After https://i.imgur.com/pc8dXLvh.jpg […]
After
Nice, though you missed adding back one cap - near the southbridge.
PcBytes wrote on 2022-11-25, 18:53:Bancho wrote on 2022-11-25, 17:45:After https://i.imgur.com/pc8dXLvh.jpg […]
After
I'd spotted that after I'd taken the picture 😁 and proceeded to add it.
The WD-40 BRAND product range for the completely clueless https://www.wd40.com/products/
The blue torch rust penetrator is an absolute life saver working on rusty car crap.
MarkP wrote on 2022-11-25, 11:35:Shreddoc wrote on 2022-11-25, 11:28:Detergent, water and convection are even finer, and are available at your home.
If tap water's good enough for the likes of necroware and other highly respected repairers, then it's good enough for me. It's difficult to get "far far better" than a 100% success rate using tap water in the cleaning of boards over many years.
But I understand that you may make the same claim about dousing circuit boards in WD-40, if you wish. So you do you, man. WD-40 or contact-cleaner up all your stuff as much as you like. Yay planet.
Cosmic wrote on 2022-11-25, 18:17:There's all this talk of WD-40 for cleaning electronics here... how about Deoxit? Some retro YouTubers seem to swear by it. "Deoxit that socket!" - Adrian's Digital Basement
Exactly. A socket is a moving contact. Where two separate surfaces move in and out of contact with each other. That's what contact cleaner is for. Not for general dousings of circuit boards, as though it were some magical improver or protector for electronics in general.
What Adrian (and other experts) are most certainly not saying, is "as a general rule, you should douse all your circuit boards all over in WD-40 or contact cleaner".
Shreddoc wrote on 2022-11-25, 20:59:If tap water's good enough for the likes of necroware and other highly respected repairers, then it's good enough for me. It's d […]
Don't be stupid and over sensitive dude.
Facts don't care about feelings.
