Reply 26680 of 27586, by Bruninho
Backing up my retro and modern vms. the QEMU Ubuntu vm bricked during an update. I lost a few tiny shit, but nothing worth crying... moving on
JOBS, Steve.
Reply 26681 of 27586, by Shponglefan
Started diagnosing this non-working Voodoo3 2000 3000 PCI.
1.06 MiB
719.55 KiB
It had a bunch of tiny scratches on the back. Nothing too serious looking until I found one broken trace.
Now to figure out the best approach to repairing it...
168.01 KiB
edited:
Turns out it's actually a Voodoo3 3000! I thought it was only a 2000, but the BIOS suggests otherwise.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 26682 of 27586, by Nexxen
Shponglefan wrote on 2024-02-08, 22:59:
Doesn't look too difficult, boring would be more appropriate.
Scratch a bit more, flux, tinning, copper wire, solder mask. Done. 30 to 45 mins IMO.
Unless you do 1 trace, that'll be 10 minutes max.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 26683 of 27586, by Shponglefan
Nexxen wrote on 2024-02-08, 23:51:
The difficulty is trying to make the repair as invisible as possible.
Running a wire isn't super difficult, but it's more noticeable. I want to attempt running a replacement trace and then masking it so it's as unobtrusive as possible.
Reply 26684 of 27586, by Nexxen
Shponglefan wrote on 2024-02-09, 00:08:
That is quite a trick you are trying to pull. In my experience the issue is to position exactly another flat trace on top of it.
This requires a donor trace, and the tiny thing ain't come off easily and neat. I only succeeded with big ones.
Or you could use a copper wire flattened and cut to required width. Visual impact would be minimal.
Please, post a pic when done. This is interesting for future repairs.
Good luck!!
Reply 26685 of 27586, by Shponglefan
Nexxen wrote on 2024-02-09, 00:59:
I thought about trying to use a donor trace, but like you say, it's hard to cut them out and have them remain straight and intact. These particular traces are only 0.13mm wide.
I have some circuit trace in spools, but the narrowest I have is about 0.25mm.
What I'm thinking of doing is first covering the exposed traces with solder mask, then exposing some copper on either side of the broken trace and running the replacement trace over top. It's going to be thicker than the original trace, but I'm hoping won't cause any issues. The biggest concern I have is inadvertently bridging a couple traces together.
Good luck!!
Thank you! I'll make sure to post a pic of how it goes.
Reply 26686 of 27586, by Shponglefan
Voodoo3 repair successful!
845.96 KiB
173.49 KiB
I started by laying down solder mask to cover the existing exposed traces. Then I scratched out either side of the broken trace, tinned the exposed copper, then soldered a piece of 0.25mm trace overtop.
This was a PITA to try to solder. The tiny piece of copper trace I was using kept floating around in the flux. But eventually got it aligned and tacked down.
Tested with my multimeter and seemed like it had successfully bridged the broken trace.
444.19 KiB
Booting up, it turns out this card is actually a Voodoo3 3000 according to the BIOS startup screen. I had thought it was a 2000 originally, so that was a pleasant surprise. 😁
I haven't put any solder mask on the final repair, as I'm going to test out the card some more first. It might not be completely invisible, but I don't think it looks too bad, even without the solder mask.
Reply 26687 of 27586, by Horun
Good work !
Reply 26689 of 27586, by blakespot
I "tooted" from my 5x86 today, and followed with some selfie pics, thanks to DOS Mastodon client (that runs on a Javascript implementation for DOS (!!!!!)), DOStodon.
https://oldbytes.space/@blakespot/111898550167322715
bp
:: Visit the Byte Cellar, my vintage computer blog (since 2004).
:: See a panorama of my own Byte Cellar (a.k.a. basement computer room)...
:: twitter: @blakespot
Reply 26690 of 27586, by THEBaratusII
I was tinkering around with Visual Basic 4 (on my Pentium II 450MHz machine with Windows XP) attempting to make smooth movement code. It didn't work 🤣
My Website
YouTube Channel
Reply 26691 of 27586, by pan069
THEBaratusII wrote on 2024-02-09, 07:34:
I was tinkering around with Visual Basic 4 (on my Pentium II 450MHz machine with Windows XP) attempting to make smooth movement […]
Looks interesting. Haven't touched VB for a good 20+ years now so I have no tips or pointers for you other than to point you into the direction of archive.org. But with a bit of googling (or maybe even ChatGPT) you might be able to come up with some good solutions.
https://archive.org/search?query=visual+basic+graphics
Reply 26692 of 27586, by Nexxen
Shponglefan wrote on 2024-02-09, 03:10:
Horun wrote on 2024-02-09, 03:02:
Good work !
Thank you! 😁
Well, nicely done!
Reply 26693 of 27586, by iraito
Shponglefan wrote on 2024-02-09, 02:36:
Voodoo3 repair successful! […]
Nice! i had to do a similar mod for my sega saturn model 2 to make it work at 60hz, i usually use a slightly thicker copper wire by cutting some old braided copper cable and getting a single strand out.
Also to make it so that the wire doesn't float you could tape both ends of the wire down and put it in place before soldering.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 26694 of 27586, by Kahenraz
I think that code will only work based on the auto repeat of the keyboard when holding down a key, which will have a delay. You need to test for keydown, interpolate based on a timer, and then stop once the key is released.
Reply 26695 of 27586, by Shadzilla
Wololo!
Continuing to 'legitimise' some gaps in my retro games collection. Lovely boxed copy of original AoE with all the manuals and paperwork inside 😀
Reply 26696 of 27586, by chrismeyer6
Shadzilla wrote on 2024-02-09, 13:38:
Wololo!
That's a great find. I still have the box complete with booked and manuals for AOE2. Sadly my box for AOE and rise of Rome got ruined when my in-laws basement flooded
Reply 26697 of 27586, by H3nrik V!
Good work! However; such a short break, I would've probably just flux'ed and drawn solder across it ...
Reply 26698 of 27586, by Shponglefan
H3nrik V! wrote on 2024-02-09, 15:26:
I'd considered that but my concern was the close proximity of the other exposed traces. From the top exposed trace to the bottom exposed traces was only 1 mm. Even applying solder mask and then re-exposing and trying to bridge the broken bit seemed a bit risky to me.
I didn't want to risk the possibility of creating a bridge given that would be more difficult to clean up and then potentially cause more damage in the process.
Reply 26699 of 27586, by PD2JK
Today I used about the quarter of a Deoxit can, just to clean the CPU slot of an Asus K7M. Then I bent a few pins IN the slot back to normal position. And now it POSTs!
